Undarcar Led
Old Apr 20, 2006 | 02:09 AM
joprout's Avatar
joprout
Default Undarcar Led
I'm looking to buy undercar led's but I'm wondering if it will actualy fit? Did anyone installed some? Any pictures?
Thanks
Old Apr 20, 2006 | 04:02 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: Undarcar Led
White Varad LED underbodies
About 200 bucks for the set, only annoying part to the installation was the drilling into the firewall to fit ALL of the wires through. they're flat and hide easy behind the pinch weld.
Old Apr 20, 2006 | 07:08 PM
PSI Chick's Avatar
PSI Chick
i have the same kit, works great!
Old Apr 20, 2006 | 09:29 PM
LilSparkPlug
Yeah I've had it on over a year now, and I love it. So many different options of motion, dimming, etc to choose from too. PSIChick where is your controller mounted?
Old Apr 20, 2006 | 09:50 PM
PSI Chick's Avatar
PSI Chick
under the center console. the switch is drilled in between the ebrake and the top of the arm rest. made it quite a pain to change shifters, and now i need to get under there again to install a rod break, i'm not looking forward to it. everything is soldered under there....
Old Apr 20, 2006 | 10:28 PM
LilSparkPlug
Mine had adhesive on it, and its a HUGE switch with 6 or 7 LEDS in it. It fit perfectly to the left of the change holder under the console.
Old Apr 20, 2006 | 10:57 PM
vaughn's Avatar
vaughn
all you too need now is a disco ball hanging from the headliner.... maybe some fur on the dash.....and some bee gees running threw the speakers[sm=yeahsmile.gif][sm=icon_ladiesman.gif]
Old Apr 21, 2006 | 04:38 AM
PSI Chick's Avatar
PSI Chick
haha i shoud post up pictures of all my lighting mods...i got the blue led dash kit, the dome light is now a board with about 45 blue leds in it, and the underbodies.....
Old Apr 21, 2006 | 05:27 AM
black4's Avatar
black4
are those legal to drive around with them on?
Old Apr 21, 2006 | 11:28 AM
PSI Chick's Avatar
PSI Chick
it seems to vary from state to state the laws on underbodies. in ny, white is the only legal color and it's only legal if you can't see the bulbs. check your local laws on that one.....
