Dyno Help!!!!!
I just went to Dyno yesterday and they told me that my car is running
extremely rich and i dont have enough air, they
told me that i had to get a air fuel controller. It only run 238 WHP at 18
psi and i got all the mod like Stage 2 without toy, 3inch down pipe, mopar
exhaust system, K&N intake, MSD coil and wires. Please help me, i dont
want to get the air and fuel controller because the dealer is very bitching,
the last time i got the turbo timer, they got 1 wire connected to the wheel
speed sensor and it broke they said that there was a after market wire
so ihave to pay for the damage. Somebody suggested me to get a fuel cut defender to solve the problem
i dont know if it would help. Please tell me what to do.
unplug the black line that comes to the turbo to the wg and that will fix your problem and give you alot of power.
i dont recommend it, but you will love it.
SAFC is the cheapest way to go. Also, Map clamp so you can lean out your car little, dont go over 12, you should get 12 and lower a/f
i dont recommend it, but you will love it.SAFC is the cheapest way to go. Also, Map clamp so you can lean out your car little, dont go over 12, you should get 12 and lower a/f
