BOV?
Old May 4, 2006 | 04:26 PM
flameredsrt's Avatar
flameredsrt
Default RE: BOV?
i think it is coming from the intake,but what could it be and if its coming from the intake that means the BOV isn't doing anything?I keep adjusting the screw on top the bov(took all the way out and started fresh)and i cant get anything different out of this thing,i have switched my lines around for my vac source and still no change,i hope someone can give me a lil insight before i damage something?
Old May 4, 2006 | 05:19 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: BOV?
No it doesnt mean that the BOV isnt doing anything, when Im under PTB (part throttle boost) I get a LOUD flutter coming from the intake but its compressor stall....try to stay away from that.
Aftermarket BOVs wont blow off the same way a Mopar plate will, you really have to be boosting in order to get it to go off (i.e. over 5psi)
Old May 4, 2006 | 05:37 PM
flameredsrt
Default RE: BOV?
even in possitive boost it still just flutters but its louder than just drivin normal..Thats the only difference i see is it does the same thing just the sound gets louder still NO psssssssssssssssss!!!!!
Old May 4, 2006 | 06:53 PM
flameredsrt
Default RE: BOV?
So i did a lil research and went to turbonetics website,they say that i need a boost source and a vac source,i have the vac source from the TB but there is another opening underneath the top plug that i am suppose to have a line ran to???I am curious that no one ever told me this do i really need it for it to work?This thing is driving me crazy someone with a aftermarket BOV please give me input on how you got ALL your lines ran to the BOV?thanks
Old May 4, 2006 | 07:02 PM
MChat's Avatar
MChat
Default RE: BOV?
I was told not to hook the bottom line up as it was more for someone wanting to run less boost and have the BOV still open.
I'd still like to see a pic of how you have it hooked up...
Also, how does your car respond under boost? Does it hold boost and run like it should?
Old May 4, 2006 | 07:17 PM
flameredsrt
Default RE: BOV?
Other than i have a boost leak(had it since i installed stage 2 damn zip ties)it feels the same..I was doing a lil more lookin around and i found a HOW TO and it showed that i need the back part of the T to run inline with the big black line that has the check valve in it?I didn't do this could that be my problem?
Old May 4, 2006 | 08:22 PM
flameredsrt
Default RE: BOV?
Can someone with a aftermarket BOV post some GOOD pics on how you have the vac lines ran for the bov?I would greatly appreciate it.I dont have access to a camera.
Old May 6, 2006 | 08:11 PM
topheraz's Avatar
topheraz
Default RE: BOV?
I have the Raptor BOV as well. I have a flutter noise when near or under 0 psi. Was told this is fine. But when i get to as little as like 3psi my BOV makes a nice noise. I also have AEM intake, dont know if noise is from BOV or intake, but there is a flutter noise on mine too. I had Apex Motorsports install all my stuff so far, dont know if any of you in AZ. I imagine they did everything right so im guessing the flutter is fine.
Old May 6, 2006 | 08:33 PM
topheraz's Avatar
topheraz
Default RE: BOV?
Well i tried to get you a pic, hehe used my camera phone. This is the only line i have coming off my BOV. This shows where it connects just above. Hope this helps [&:]
Old May 7, 2006 | 02:50 PM
MChat's Avatar
MChat
Default RE: BOV?
I found the stock vacuum diagram and enhanced it and then modified it to show how the BOV should be hooked up:
Before BOV:
After BOV:
You should note that the bottom line to the stock solenoid is what is re-routed to the BOV. If this line is still hooked up, it would likely cause your fluttering noise.
