BPP - Stealth Bulbs?
Old Jun 5, 2004 | 02:12 AM
Barneydriver's Avatar
Barneydriver
Default RE: BPP - Stealth Bulbs?
Both are really easy- search the forum- I posted some (overly) detailed instructions on how to change the side marker lights.
As for the tailights, just pull back the carpet, remove the fasteners, pull the tailight out, twist the bulbs out, and re-assemble in reverse.
Old Jun 5, 2004 | 02:16 AM
Bildo's Avatar
Bildo
Almost sounds idiot proof, but I guess I'll find out. Thanks Barneydriver.
Bildo
Old Jun 5, 2004 | 02:18 AM
Barneydriver
pleasure.
Old Jun 5, 2004 | 03:57 AM
BPP's Avatar
BPP
model number for the front turn bulbs is #3357 #3457
In the morning i wil get a list of srt bulb number together for yall.
Parking light number #3457
Rear turn Signal #3157
Side Marker #168
This is for the neon srt4 and normal neon
Once again dont forget to enter the code for free shipping SE200
Old Jun 5, 2004 | 07:27 AM
Bildo's Avatar
Bildo
I looked through the first 12 pages and couldn't find your instructions for the sidemarkers. Any way you can narrow it down for me? Thanks
Bildo
Old Jun 7, 2004 | 07:42 AM
71RoadRunner's Avatar
71RoadRunner
Well, I know what I need to buy now. I've wanted to get rid of my SRT-4's cross eyed look, although it will still be that way at night. Thanks for the info.[sm=smiley20.gif]
Old Jun 7, 2004 | 10:17 AM
SRT_YA's Avatar
SRT_YA
Bildo
I don't know where the post is, but the side marker lights are as follows (for me at least, it took me 10 mins for my car).
1) If you have a hyd. jack or such, jack car up on desired side to work on (if driver side, jack up driver side, etc.) and turn the wheel all the way to the left (again for the driver side) - do the opposite for the passenger side
2) If you are small, or don't mind getting a little dirty, crawl under your car in front of the tire (not under the tire!)... and look up
3) Once you see the side marker light "assembly" take the bulb out (it's just twisted in there), and notice there is a metal clip/tab that you pull perpendicular to the light (hence, you pull the tab in the same direction as the body lines are - towards the back of the car)...
4) with the clip removed, the light should slide out of the plastic tap and be in your hands now
5) Install is reverse of removal
6) NOTE: on the passenger side, I did all the same steps, except when it came time for the install, I pushed the light bulb back through the side maker light hole in the fender, then put the whole thing back in instead of putting the marker light in and then the light bulb... either way... 10 minutes tops for me...
I also left the "clear" bulbs in it for now (yes, it may be illegal - but... it looks better silly amber bulbs... frontin' on my style hehe... if you need more info or pics - let me know...
also, BPP - I couldn't get your SE200 code to work booo... either way, I still order a pair of lights this morning
Old Jun 7, 2004 | 07:35 PM
Bildo's Avatar
Bildo
Thanks SRT_YA. Those instructions should prove to be most helpful when I get the sidemarkers. I also couldn't get the code to work (SE200) but ordered anyway. It's only $3. Thanks again.
Bildo
Old Jun 10, 2004 | 06:18 PM
Bildo's Avatar
Bildo
I got my bulbs yesterday. They are pretty nice. I like the new look. Did anybody with the stealth bulbs have any problems with fuses? I had 2 fuses blow when I put them in. I have replaced one and have to go get some more to replace the other. It took out my instrument panel light, my taillights, and the remote keyless entry.
Bildo
Old Jun 10, 2004 | 07:52 PM
SRT_YA's Avatar
SRT_YA
darn it! I haven't gotten mine yet!!! ARGH!!! hahaha...
hmmm... hopefully I won't have the same problem, if I do... I'll let you know!
