MM inserts
its not hard at all.. you dont need to lift the motor.........you really dont even need to support the motor.......just make sure your on level ground.......do the top first
the hardest part is doing the bottom......you got to take off the wheel splash shield...... about 30 minute job total..........and if you got some use thread lock
