Rear sway bar
I have a rear sway bar(adjustable) from ebiach, anyone else have this piece? It is sure beefer then the stock little one but i cant seem to fiqure out how to install it. It says that in order to install the rear sway bar with adjustablility i need to swap my rear struts around, anyone else had to do that? What rear sway bar just bolts up and is done with it?
Jordan
Jordan
well emailed the guy who sold them to me, i waiting on a reply on how he installed them on his srt-4....i quess i will wait to what he says. The end on the rear sway bar doesnt line up with the stock end links it goes the opposite direction.
Jordan
Jordan
well he said you have to switch the struts around for the install the sway bar...screw that not happening. Im buying a different rear sway bar then.
Jordan
Jordan
Trending Topics
doesnt sound right at all should have 4 bolts and 2 nuts if its non adjustable there is no reason why you should have to swap anything around it only took 30 mins to install my rear bar.
its adjustable, and thats why ebiach says in order to bolt it correctly with it being adjustable you need to switch the struts around in order to have the room to mount up the bracets.
I think im geting some other sway bars anyways.
Jordan
Jordan
