Falling apart
Old May 4, 2006 | 01:27 PM
Valo2170's Avatar
Valo2170
Default Falling apart
I know this is not a big deal but i think its just funny that i cant get my **** into 3rd anymore and now this.OK is this bad wires?When ever i floor it i can feel it jerk and i can here some pops out the turboback.Its like it just keeps jerking while i floor it.not all the time but some time.you guys know when a car is just seting there and if it is amissing you can tell?thats what it seems like when you floor it. So anyone?
Old May 4, 2006 | 02:50 PM
Burnout_INC's Avatar
Burnout_INC
Default RE: Falling apart
If theres a lot of "jerking" and popping out the exhaust at WOT then you need a tune up, go over your wires and look for cracks, spark plugs are junk more than likely as well.
Old May 4, 2006 | 03:00 PM
LilSparkPlug's Avatar
LilSparkPlug
Replace the plugs/wires anyways, leave the coilpack there. Stock coil is the best.
Check your TPS wire, since thats a huge issue also.
Popping and jerking, does it blow black smoke too? Almost sounds like limp mode due to a bad map sensor, but it couldnt be since you said "only sometimes" not all the time.
Old May 4, 2006 | 03:02 PM
PSI Chick's Avatar
PSI Chick
bad wires and plugs....just replace them and you'll be fine.
Old May 4, 2006 | 11:36 PM
m88s22's Avatar
m88s22
had the same problem. replace plugs/wires. should be fine
Old May 5, 2006 | 02:12 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
I agree, if you have more than 5,000/6,000 miles on the factory wires and plugs, save yourself some trouble and replace them......MSD wires have held up well for me for over 2 years.....
Dusty
