Cold Starts
Old May 12, 2006 | 03:04 PM
300ZXSRT4's Avatar
300ZXSRT4
Default Cold Starts
Lately in the morning when I start up my SRT-4 it has trouble starting, I usually have to press on the gas a little to get it going right away. My car only has 15,000 miles on it. It seems to be not getting enough spark all of a sudden. Anyone else having this problem out of nowhere?
Old May 12, 2006 | 04:39 PM
srt4_roller's Avatar
srt4_roller
Default RE: Cold Starts
check to make sure your fuel pump isnt busted or that your wires, plugs or coil pack arent burnt out!
Old May 13, 2006 | 02:22 AM
LilSparkPlug's Avatar
LilSparkPlug
My fuel pump and injectors were bad. Its mainly the switch to summer gas from winter gas thats gonna give the car a hard time starting up. You can change your plugs/wires (they're cheap enough some do this at 3-6,000 mile intervals) and see if that helps as well. Reset your PCM while your at it.
Old May 15, 2006 | 01:17 PM
300ZXSRT4's Avatar
300ZXSRT4
Cool, thanks.
Old May 15, 2006 | 03:53 PM
PSI Chick's Avatar
PSI Chick
the the system pressurize before you start the car
