holding boost???
Old May 20, 2006 | 02:49 PM
datdude05's Avatar
datdude05
Default holding boost???
Ok, i installed my stg 1 ecu a couple weeks ago expecting to hold all my boost. i also have an agp wgt n i closed the bolts all the way. I turned the mbc all the way down, now im boosting 20 psi holding between 15-17 on a hot day n holding 16-18 on a regular night. My question is what do i need to boost 20 n hold 20 psi?
Old May 20, 2006 | 06:41 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: holding boost???
ALOT more than what you have. Spiking 20 on a stock fuel system is bad for your AFRs, thats seriously lean.
Holding 20psi is very difficult on the stock turbo. You'd have to spike over 20 to hold it.
Old May 21, 2006 | 06:29 AM
Four Banger Anger's Avatar
Four Banger Anger
you should only spike 17-18 on a stock turbo anyways, i was told its to much for the the system and you will throw a overboost code....but maybe with stage 1 its different, im not to sure.
Jordan
Old May 21, 2006 | 02:59 PM
datdude05's Avatar
datdude05
the stage 1 ecu is allows ur car to run more fuel and also since i installed it i had no check ingine light so thats a plus.
