ECU REFLASHED
Old May 30, 2006 | 04:13 PM
RIPSIGUY's Avatar
RIPSIGUY
Default RE: ECU REFLASHED
For the "sake of pete"! It's not a reflash. All your doing is configuring the SKIM key system to your car.
When you call a dealer and say" reflash", they're thinking of something totally different.
Remove that "FLASH" word from your vocabulary.
Old Mar 22, 2007 | 05:46 PM
killer1562001's Avatar
killer1562001
the new address is
33820 Riviera Drive
Fraser MI. 48026
Att. Stephanie/Reprogram
ORIGINAL: vaughn
http://www.flightsystems.com/About_Us.htm
Hello,
If you have bought a used stage kit and need your vin number reflashed into it you can send your pcm to me and I can reflash it for you. I can NOT reflash stock pcm's. As you should know, if you do not do this and try to install the pcm in your vehicle without changing the vin, your vehicle will not start. The charge for this will be $30 plus s&h plus the COD charge. I can either ship it back to you overnight air which is expensive or ground which will only cost $4-5 more on top of the $30 plus the $7 charge for COD. The cost for everything will be around $43 which will come COD (collect on delivery). Everything will be sent back using the carrier UPS, no exceptions. When the driver drops your pcm off you must give him a check or money order made out to Flight Systems, for the exact amount. Once I ship your pcm out, I can send you a pm with your tracking number and total COD amount. The address you will need to send it to is:
Flight Systems
1040 East Maple Road
Troy, MI 48083
Attn: Stephanie/Reprogram
Please make sure to put inside the box your vin number, return address, a telephone number I can reach you at in case of any problems, and how you would like it sent back to you; ground or overnight. Please make sure the pcm is packaged properly, any damage that happens on delivery to me is not my respondsibility. Let me know when you are sending it out to me by pm so I know when it should arrive. I will ship it back out to you 1-2 days after I receive the kit. If you have any questions, you can pm me as well. Have a great day!!
Stephanie
Flight Systems
Parts Department
Old Mar 22, 2007 | 06:16 PM
monstab757's Avatar
monstab757
Street Demon, why the hell do you have two BOVs? Are you running a twin turbo set up?
Old Mar 22, 2007 | 10:24 PM
Plan B's Avatar
Plan B
ORIGINAL: street demon
DOES ANYONE HAVE AN IDEA ABOUT HOW MUCH IT MITE COST TO REFLASH A STOCK ECU FROM THE DEALER?
I called six different dealerships in my are. 3 refused to do it and the other three wanted to charge me $100. This was for a used stg1 though. What are you trying to do to the stock ecu? There is a local shop around here that claims they can crack any ecu and reprogram it, but I have my doubts...
Old Mar 23, 2007 | 03:42 AM
silverblacksrt4's Avatar
silverblacksrt4
i got a new stage 2 and they wanted my miles too.. wonder why!
Old Mar 23, 2007 | 10:36 PM
SMTYLEZ's Avatar
SMTYLEZ
WHATS THE PURPOSE OF REFLASHING? WHY DO IT WHAT DOES IT DO?
