Stage 2 and 3 turbo upgrades
Old Dec 20, 2003 | 02:36 AM
71RoadRunner's Avatar
71RoadRunner
Default Stage 2 and 3 turbo upgrades
Thank You very much. <img border="0" src=smileys/smiley4.gif border="0"> <img border="0" src=smileys/smiley4.gif border="0"> <img border="0" src=smileys/smiley32.gif border="0">
Old Dec 29, 2003 | 05:36 PM
Gargoile's Avatar
Gargoile
Here are some more part numbers care of AbuBamsry</P>
http://www.srtforums.com/forums/show...?s=7a3aebc0a0d 6d018aa525f4c4555328a&amp;threadid=10025&amp;highl ight=part+ number+list</P>
<U>STAGE UPGRADE PACKAGES
</U>
<FONT size=2>Mopar SRT-4 Stage 1 [2003] (P5007862, $399.00)
-527 cc/min Injectors (Mis-Printed)
-577 cc/min Injectors (Corrected)
-Stage 1 PCM
Mopar SRT-4 Stage 1 [2004] (P4510592, $399.00)
-Stage 1 PCM
Mopar SRT-4 Stage 2 (P5007863, Under $2,000.00, December 2003 - February 2004)
-682 cc/min Injectors
-Stage 2 PCM
-Upgraded Wastegate Actuator
-3.0 Bar MAP Sensor
-3.0 Bar TIP Sensor
-2.5" Cat-Back Exhaust System (Required but Sold Serperately)
-Turbo Toys Hardware and Components
--Dial-a-Boost (4-pos Thumb-wheel)
--Intercooler Sprayer (w/ switch)
--Pump vs. Racing Fuel Switch
--All necessary wiring, switches and mounting hardware
Mopar Stage 3 [FULL] (P5007864, Early-Mid 2004)
Mopar Stage 3 [Add-On to Stage 2] (P4510256, Early-Mid 2004)
-Stage 3 PCM
-TD05HR-15GK@-10cm2 Upgrade Turbo Unit
--16% larger compressor wheel diameter to flow and compress more intake air
--19% larger turbine wheel diameter to flow more exhaust gas and reduce back pressure
--67% more turbine scroll area for reduced back pressure
-High Flow (75psi) Viper Fuel Pump Module
-Demand-Regulated Fuel Rail Assembly
Mopar SRT-4 Stage 3-R (Under Development)
-Stage 3R PCM
-719 cc/min Injectors
-Cat Delete Exhaust (Race Pipe)
-Other
Watch-Out For Future 'Staged' Upgrades (Under Development)
</FONT><U><FONT size=3>STAGE UPGRADE ITEMS SEPERATELY</U></FONT>
<FONT size=2>Mopar SRT-4 Stock 2003 525 cc/min Injectors (4852747AA)
Mopar SRT-4 Stage 1 527 cc/min Injectors [Mis-Printed] (N/A)
Mopar SRT-4 Stock 2004 577 cc/min Injectors (4891574AB, $55.85)
Mopar SRT-4 Stage 1 577 cc/min Injectors [Corrected] (4891574AB, $55.85)
Mopar SRT-4 Stage 2 682 cc/min Injectors (Early 2004)
Mopar SRT-4 Stage 3 719 cc/min Injectors (Middle 2004)
Mopar SRT-4 Stage 1 PCM (P4510592, $399.00)
Mopar SRT-4 Stage 2 PCM (Early 2004)
Mopar SRT-4 Stage 3 PCM (Middle 2004)
Mopar SRT-4 Stage 3R PCM (Under Development)
Mopar SRT-4 Upgraded Wastegate Actuator (Early 2004)
Mopar SRT-4 3.0 Bar MAP Sensor (Early 2004)
Mopar SRT-4 3.0 Bar TIP Sensor (Early 2004)
Mopar SRT-4 Turbo Toys Hardware and Components (Unknown Potential)
Mopar SRT-4 TD05HR-15GK@-10cm2 Upgrade Turbo Unit (Mid 2004)
Mopar SRT-4 High Flow (75psi) Viper Fuel Pump Module (Mid 2004)
Mopar SRT-10 Viper Fuel Pump (5086489AA, $550.00)
Mopar SRT-4 Demand-Regulated Fuel Rail Assembly (Mid 2004)
Mopar SRT-4 2.5" Catback Exhaust (P4510461, $385.00)
Mopar SRT-4 RacePipe [Cat Delete Exhaust Part] (Under Development, 2004)
</FONT><U><FONT size=3>SUPENSION UPGRADES</U></FONT>
<FONT size=2>Mopar SRT-4 Front Strut Tower Brace (Under Development)
Mopar SRT-4 Rear Strut Tower Brace (Under Development)
Mopar SRT-4 Stage 1 Performance Springs Kit (P4510458)
Mopar SRT-4 Stage 1 Front/Rear Anti-Swaybar Kit (P4510454)
Mopar SRT-4 Stage 2 Suspension Kit [KW Coilover Kit] (P4510447, $1,395.00)
Mopar SRT-4 Stage 3 Suspension Kit [KW Adjustable Coilover Kit](P4510586, $1,625.00)
</FONT><U><FONT size=3>SEATING UPGRADES</U></FONT>
<FONT size=2>Mopar and Katzkin One Row, Uninstalled, Premium (Leather1PU, $699.00)
Mopar and Katzkin One Row, Installed, Premium (Leather1PI, $1,035.00)
Mopar and Katzkin Two Row, Uninstalled, Premium (Leather2PU, $999.00)
Mopar and Katzkin Two Row, Installed, Premium (Leather2PI, $1,465.00)
Mopar and Katzkin Two Row, Uninstalled, Deluxe (Leather2DU, $849.00)
Mopar and Katzkin Two Row, Installed, Deluxe (Leather2DI, $1,299.00)
</FONT><U><FONT size=3>GUAGE UPGRADES</U></FONT>
<FONT size=2>Mopar SRT Air/Fuel 2-1/16" Ratio Gauge (P4510435, $75.60)
Mopar Silver Air/Fuel 2-1/16" Ratio Gauge (P4510444, $75.60)
Mopar White Air/Fuel 2-1/16" Ratio Gauge (P4510426, $74.53)
Mopar Carbon Fiber Air/Fuel 2-1/16" Ratio Gauge (P4510416, $76.80)
Mopar SRT Boost 2-1/16" Gauge (P4510525, $211.86)
Mopar Silver Boost 2-1/16" Gauge (P4510526, $211.86)
Mopar White Boost 2-1/16" Gauge (P4510420, $209.60)
Mopar Carbon Fiber 2-1/16" Boost Gauge (P4510410, $215.20)
Mopar SRT Fuel Pressure 2-1/16" Gauge (P4510434, $251.33)
Mopar Silver Fuel Pressure 2-1/16" Gauge (P4510443, $251.33)
Mopar White Fuel Pressure 2-1/16" Gauge (P4510425, $254.26)
Mopar Carbon Fiber Fuel Pressure 2-1/16" Gauge (P4510415, $257.60)
Mopar SRT Nitrous Pressure 2-1/16" Gauge (P4510436, $236.26)
Mopar Silver Nitrous Pressure 2-1/16" Gauge (P4510445, $236.26)
Mopar White Fuel Nitrous 2-1/16" Gauge (P4510427, $233.86)
Mopar Carbon Fiber Nitrous Pressure 2-1/16" Gauge (P4510417, $239.73)
Mopar SRT Tachometer 2-1/16" (P4510437, $119.73)
Mopar Silver Tachometer 2-1/16" (P4510446, $119.73)
Mopar White Tachometer 2-1/16" (P4510428, $119.73)
Mopar Carbon Fiber Tachometer 2-1/16" (P4510418, $119.73)
Mopar SRT Oil Pressure 2-1/16" Gauge (P4510431, $71.86)
Mopar Silver Oil Pressure 2-1/16" Gauge (P4510440, $71.86)
Mopar White Oil Pressure 2-1/16" Gauge (P4510422, $70.13)
Mopar Carbon Fiber Oil Pressure 2-1/16" Gauge (P4510412, $76.26)
Mopar SRT EGT 2-1/16" Gauge (P4510430, $161.46)
Mopar Silver EGT 2-1/16" Gauge (P4510439, $161.46)
Mopar White EGT 2-1/16" Gauge (P4510421, $160.80)
Mopar Carbon Fiber EGT 2-1/16" Gauge (P4510411, $161.46)
Mopar SRT Voltmeter 2-1/16" Gauge (P4510433, $47.60)
Mopar Silver Voltmeter 2-1/16" Gauge (P4510442, $47.60)
Mopar White Voltmeter 2-1/16" Gauge (P4510424, $45.73)
Mopar Carbon Fiber Voltmeter 2-1/16" Gauge (P4510414, $52.00)
Mopar SRT Water Temperature 2-1/16" Gauge (P4510432, $54.53)
Mopar Silver Water Temperature 2-1/16" Gauge (P4510441, $54.53)
Mopar White Water Temperature 2-1/16" Gauge (P4510423, $52.80)
Mopar Carbon Fiber Water Temperature 2-1/16" Gauge (P4510413, $58.93)
Mopar SRT Tachometer 5.0" (P4510429, $305.60)
Mopar Silver Tachometer 5.0" (P4510438, $305.60)
Mopar White Tachometer 5.0" (P4510419, $257.33)
Mopar Carbon Fiber Tachometer 5.0" (P4510409, $318.26)
Mopar SRT Guage Pod 2 1/16" Dual Pod A-Pillar Mount (P4510559, $37.80)
Mopar SRT Guage Pod 2 1/16" Single Pod A-Pillar Mount (P4510560, $37.80)
Mopar O2 Sensor Kit [Required For Use w/ Mopar Air/Fuel Gauges] (P4510599)
Mopar Tachometer Signal Adapter [Required For Use w/ Mopar Tachometers] (P4510598)
</FONT><U><FONT size=3>LIGHTING UPGRADES</U></FONT>
<FONT size=2>Mopar SRT-4 SilverStar Headlight Bulb [9007] (P0009007ST, $27.00)
Mopar SRT-4 FogLight Bulb [89x Series] (N/A)
</FONT><U><FONT size=3>TRANSMISSION UPGRADES</U></FONT>
<FONT size=2>Mopar SRT-4 Limited-Slip Differential ['03 Upgrade, Quaife] ($1400, P5007923)
Mopar SRT-4 Limited-Slip Differential ['04 Replacement, Quaife] ($1900, 5127732AA)
Mopar SRT-4 Limited-Slip Differential Installation Kit ['03 Upgrade] (P4510588)
Mopar SRT-4 Upgraded Flywheel (Under Development)
Mopar SRT-4 Upgraded Half Shaft [Right] (Under Development Early 2004)
Mopar SRT-4 Upgraded Half Shaft [Left] (Under Development, Early 2004)
Mopar SRT-4 Upgraded High Torque Clutch (Under Development, Early 2004)
Mopar SRT-4 Short Throw Shifter (P4510485, $11
Old Dec 31, 2003 | 03:37 AM
andybuzz2u's Avatar
andybuzz2u
About time someone posted the prices you sure as <IMG src=smileys/smiley35.gif border="0">can't get them from mopar any more. They told me to wait till feburary?
Old Jan 13, 2004 | 06:55 AM
kastan6936's Avatar
kastan6936
where is the stage 3 web site</P>
</P><edited><editID>kastan6936</editID><editDate>37999.1645138889</editDate></edited>
Old Jan 17, 2004 | 10:02 PM
andybuzz2u's Avatar
andybuzz2u
Does anybody out here have the prices for the stage 2 kit? A friend of mine recently purchased a black srt-4 with the sun roof and side bags and those cheap looking neon seats(<IMG src=smileys/smiley11.gif border="0">). She wants the stage 2 kit, even though im trying to talk her out of it, but she wants it to stay under warranty and the fact that everything i mod blowssooner or later? ANYONE?
Old Jan 20, 2004 | 03:15 AM
bluert's Avatar
bluert
Here's some pics of the turbo toys: http://www.srtforums.com/forums/show...?s=&amp;thread id=31814<IMG src=smileys/smiley32.gif border="0">
Old Jan 20, 2004 | 04:07 AM
71RoadRunner
Those pics appear to have been taken at the Mopar Nationals in their display set up. They also had a cut open new 5.7L Hemi.
Old Jan 20, 2004 | 04:18 AM
HEMI ?'s Avatar
HEMI ?
well just to fill yall in the prices are not out yet in chrysler and as far as warranty work goes dude you have to give them your vin number and miles if you wanna order it so far i have not heard of a total void of warranty but it may be a catch 22</P>
most of the time its dealer descretion and where igo their is none<IMG src=smileys/smiley4.gif border="0"></P>
by the way the new catalogs stink they omiited half the stuff in them to put pics in and then they dont even have half the stuf available to order or even a date at which you can.</P>
the new chick mopar has in charge needs to ge a pair if yall know what i mean******no offense to any ladies here but she just dont know is all if you aint never had a car to tinker on you shouldna got the job is all i'm sayin*************</P>
and thats the bottom line cause i said so</P>
Old Jan 21, 2004 | 09:08 PM
forcefed's Avatar
forcefed
Well, I work for Gresham Dodge in Oregon and I keep bugging the parts guys askin em when I can get a price on the Stage 2 and 3 but nothin has changed in the computer, but trust me I will know the day they start rolling em out. By looking at some of the equipment that comes with the Stage three I bet the price is going to be significantly more because of the new turbo unit, I think i will just go with the stage 2, possibly a little laughing gas??! <img border="0" src=smileys/smiley36.gif border="0">
Old Jan 26, 2004 | 08:32 PM
crazy_t_bird's Avatar
crazy_t_bird
I'm saving for a downpayment on a SRT-4 here at home but as soon asI get my "affairs" in order, a stage 2 kit will undoubtedly be at the top of my list
