Oil Pressure
Old Jun 5, 2006 | 10:24 PM
Plan B's Avatar
Plan B
Default Oil Pressure
So the other day I was driven and some guys in a honda thought it would be funny to front on me. Naturally I had to rep, so I stomped it in second and gave them a healthy dose of blow off valve and exhaust notes... About a mile later I noticed my Oil Pressure light was alluminated. Got home and checked for codes. It gave me a P0566? Whichever ojne states Oil Pressure (Which wasn't a big help btw, the light means the same thing). I just did an oil change about 800 miles ago so I jacked up the car and checked everything over (drain plug, filter, etc.). I couldn't find any leaks. I checked the oil level and it seemed slightly low. I added a little over half a quart, reset the PCM, and haven't got any codes/lights since. I beleive I fixed it quite easily and that could be the end of the story, but with the oil change not that long ago and using Amsoil (not supposed to burn at ALL, or so they claim) I was wondering if there was anything else I should double check. Mostly because a problem with Oil Pressure scares the $h1t out of me. All I can think is "If that wasn't it, this is going to cost me!" Any ideas? Or am I just paranoid?[&:]
Old Jun 5, 2006 | 10:36 PM
vaughn's Avatar
vaughn
Default RE: Oil Pressure
you do have a catch can???........in 3000 miles i probably catch almost a quart of oil
Old Jun 5, 2006 | 10:51 PM
Plan B's Avatar
Plan B
Yeah, I got a CC, but I know I haven't emptied out anything even close to a quart since I changed the oil 800 miles ago.....
Old Jun 5, 2006 | 11:04 PM
vaughn's Avatar
vaughn
yea sorry man..... i miss read your post[&o]....
Old Jun 5, 2006 | 11:13 PM
Plan B's Avatar
Plan B
It's all good! At least you chimed in! It's nice to see that rack you got as your avatar as well, that pic always distracts me at work! Any story behind it?
Old Jun 6, 2006 | 12:25 AM
vaughn's Avatar
vaughn
was looking at dirty pictures and found it......thought it would be a good avatar
honestly i got the picture off my space....it was animated untill i resized it
