STOCK BOOST QUESTION?
Old Jun 6, 2006 | 04:05 PM
street demon's Avatar
street demon
Default STOCK BOOST QUESTION?
WELL IVE BEEN TOLD THAT THE STOCK BOOST LEVEL SHOULD BE 15PSI IS THAT SOUND ABOUT RIGHT? I THINK I HAVE A BOOST LEAK BECAUSE IM ONLY AT 12PSI RIGHT NOW. NEED HELP!
Old Jun 6, 2006 | 04:15 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: STOCK BOOST QUESTION?
Start by checking the most common places for leaks as shown below.....
Dusty
[IMG]local://upfiles/894/51FE1F103CFC4D539A90FDE1176CCC4A.jpg[/IMG]
Old Jun 6, 2006 | 04:44 PM
Valo2170's Avatar
Valo2170
what you mean 12psi to redline? it should be around that.It should peak at 14-15psi than drop to 11-12psi to redline mabye even 10 in some low gears.If you dont have a wga than that is normal but if you do have a wga that you have a boost leak.It drops so much with the stock wg because it has a weak spring in it.
Old Jun 7, 2006 | 05:12 PM
street demon
NO NO NO JUST WANTED TO CHECK MY PSI LEVEL AND IN HIGH GEARS LIKE AFTER 3RD I WONT GO PAST 12PSI.
