View Poll Results: A poll
add the stripe
63.64%
do not add the stripe
31.82%
your poll is dumb get a life
4.55%
Voters: 22. You may not vote on this poll
should i add stripe or not??lease help me decide
Old Jun 14, 2006 | 08:14 PM
  #21
vaughn's Avatar
vaughn
Default RE: should i add stripe or not??lease help me decide
i dont really care who has them on the internet...........around my real world nobody has them
Old Jun 14, 2006 | 08:26 PM
  #22
vaughn's Avatar
vaughn
i mean im glad others have them..... but i only see them online.....
Old Jun 21, 2006 | 10:13 PM
  #23
vaughn's Avatar
vaughn
well i got the stripes today.....after work.....went out and put one side on.........i ended up with way to many bubbles.... and i had a small dip in the middle...so i took them off.... im going to buy anotherer set.and have someone professional do mine.............................................. .screw decal applying lol
Old Jun 22, 2006 | 12:27 AM
  #24
vaughn's Avatar
vaughn
well i ordered a new set........i may try to apply again.......any tips are welcome
is it common to have some bubbles that you cant get out?..
i read the sticky on applying the decals.....but i need extra help lol
Old Jun 22, 2006 | 08:47 PM
  #25
Jims04srt's Avatar
Jims04srt
Some small bubbles are common. It will take a day or two for the water to evaporate and then you can push them in.
Some other tips
Cut off as much extra backing paper as you can. This will help you align it better.
Tape the entire stripe w/ backing paper to the car
-- Tape it on the top part of the stripe
-- Use the bottom part for alignment tape (Have the stripe lay flat to the tape, but not touching)
-- make tic marks throughout the stripe on both the tape and stripe paper
-- draw a line on the paper where the door jams are. It should be in 4 sections.
-- remove the stripe, leave the alignment tape as a guide when you put the pieces of the stripe back on.
-- Cut the stripe into the 4 sections
-- Apply one section on at a time
Hope this helps...if not, I'll come down and put them on for you. I will accept the rims as payment.
Old Jun 22, 2006 | 08:59 PM
  #26
vaughn's Avatar
vaughn
hey thanks Jim......some more good tips...... come down put them on and 200 for the rims and tires i got a extra bed room with cable for you to sleep
my stripes came on one big sheet together..i had to cut down the middle to divide them.... the cut turned out to be the bottom of each decal
