#4 cylinder misfire
Old Jun 26, 2006 | 09:48 PM
iconoclast13's Avatar
iconoclast13
Default #4 cylinder misfire
I have had the trouble code #4 cylinder misfire on my 03 srt4 for about 2 months now. Parts replaced so far- plugs, wires, injector, and coil- all by the dealer. Has anyone had a similar problem or any idea what might be causing this problem? Thanks
Old Jun 26, 2006 | 11:11 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: #4 cylinder misfire
What kind of wires did the dealer replace them with? The #4 wire is famous for melting/heat related problems.
Dusty
Old Jun 27, 2006 | 03:36 AM
LilSparkPlug's Avatar
LilSparkPlug
Upgrade the plugs and wires, see if that helps. Theres not too much else it could be, unless its far deeper than that.
Old Jun 27, 2006 | 04:32 PM
carcrazy's Avatar
carcrazy
Had something similair on my 05 srt it was the crank sensor but basically error message was cylinder misfire
