How are you guys rollin' DR's?
Old Jun 28, 2006 | 01:27 AM
winniep's Avatar
winniep
Default How are you guys rollin' DR's?
I'm getting a set of 235 drag radials for my car. What's the best way to ride? Get all four tires in a DR or do I need to just get a similiar sized tire for the rear and just replace the DR's in front instead of rotating?
Old Jun 28, 2006 | 01:48 AM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: How are you guys rollin' DR's?
What kind of riding are you going to do? If it's just at the strip, the DRs in front are fine. For street use, I'd put on a similiar size tire with a decent traction rating on the rear, even though they just "go along for the ride". You don't want to hydroplane in wet weather and every little bit helps......
Dusty
Old Jun 28, 2006 | 01:49 AM
05ocsrt4's Avatar
05ocsrt4
well the DR's will wear a lot faster than regular street tires, so be prepared to replace the dr's every 5K miles or so. but my suggestion is get size matched tires for the rear, nothing special
