stage 2 install , help
Old Jun 29, 2006 | 09:53 PM
arebeaone's Avatar
arebeaone
Default stage 2 install , help
hey i was hoping some one could tell me there experence in installing a stage 2 . I ve had it for a while and now have the time to do it. are there any pit falls to watch out for do i need any thing like gasket glue or any info would be helpful. thanks
Old Jun 29, 2006 | 10:12 PM
SRT_YA's Avatar
SRT_YA
Default RE: stage 2 install , help
I think the only troubles I had when I did mine was... take your time... read everything carefully...
if you have toys - - if you have trouble with HOM not working, reverse the wires that go to the LED (only if you have trouble with it)
otherwise, with basic skills and following the directions... it can be done...
Old Jul 1, 2006 | 08:11 PM
winniep's Avatar
winniep
Stage 2 was a piece of cake. It literally only took about 45-55 minutes to do. Now, if you have turbo toys that's another story. Make sure you've got about 6-8 hours and a LOT of patience to spare. Other than tapping into the ECU wiring harness clips, I didn't really have any trouble. I found it was alot easier to disassemble the clips instead of trying to just shove the wires through. Good luck.
