Wierd beeping noise
Old Jul 14, 2006 | 05:03 PM
xXxIZZYxXx's Avatar
xXxIZZYxXx
Default Wierd beeping noise
Alright, I turn my car on today in the morning and everything is fine right, pull out of my driveway, driving down the road, chillin, enjoying my new suspension, stop at a red light, chill, sip some yogurt, then when light turns green I put it on first and drive off, then I hear a beep coming from my dash. I am like wtf, next stop light, does it again on 1st. Next stop light, it doesn't do it, I punch it on the next stop light, I get that beep sound again, kinda like when you have your brakes on or when you check engine light comes on, same sound. Any thoughts on this?
Old Jul 14, 2006 | 05:43 PM
moparman04's Avatar
moparman04
Default RE: Wierd beeping noise
check to see if your brake light comes on when you do that... you may need brake fluid, mine has done that before
Old Jul 14, 2006 | 09:25 PM
LilSparkPlug's Avatar
LilSparkPlug
Otherwise its the mystery chime!!!! I have the mystery chime, no idea why, it has no purpose, it just chimes at me. But usually romping on it in first gear if your brake fluid needs to be topped off with cause the e-brake light to flash for a second. Check that out, or top off the resivor with DOT 3 (not 4) anyways, its cheap enough. Just dont buy synthetic.
Old Jul 14, 2006 | 10:10 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Mine does it as well, always in 1st gear, before the engine fully warms up. It doesn't do it everyday, just once or twice a week and it stops after a few seconds.
Dusty
Old Jul 15, 2006 | 11:31 AM
Burnnout's Avatar
Burnnout
Make sure your door is shut all the way... i noticed mine was caused from that couple of times
Old Mar 26, 2012 | 03:45 AM
yellowsrt253's Avatar
yellowsrt253
Exclamation Mystery beeping!
ya i have the same ****.... always out of first from a dead stop.. beeps maybe 5-6 times then stops... no lights on or anything. but my E-brake light doesnt work maybe thats it idk... HELP!
Old Jun 5, 2012 | 04:17 PM
srt4acrboy06's Avatar
srt4acrboy06
One of three things that I have noticed
1. Door is open (will say DOOR above your odometer)
2. Put your seat belt on
3. Need Brake Fluid
One of these is the "mystery chime"
