Post your dyno #'s and mods if any please
Old Jul 21, 2006 | 03:24 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: Post your dyno #'s and mods if any please
3rd gear pull
80-90 degree weather
Serious humidity
14 pulls
251/311 untuned
Mods:
Custom 3" exhaust//MapClamp//Stage1//Plugs (.032)//Wires (Moroso)//S2WGA//Greddy EBC//Fan Switch Mod//180 TStat//Removed Tip Lines
I think thats it I could be wrong.
Old Jul 21, 2006 | 03:50 AM
Pressurecooker's Avatar
Pressurecooker
There are so many factors that affect what #'s you'll hit like weather or not it is a loaded or inertial type dyno, tire pressure, gas octane, state of tune at that time etc, etc. I am just trying to get enough postings to get a ballpark idea of what is normal and what is not. Also, some mods will increase torque more or hp more.
Thanks to everyone so far who has posted.
Anyone else?
Old Jul 21, 2006 | 04:06 AM
PSI Chick's Avatar
PSI Chick
dyno pulls should always be done in a gear that is closest to 1:1 ratio, for us that is 4th gear. 3rd gear dyno pulls will show higher numbers however they are not truly accurate as to the power that you're making. honda's are typically done in 3rd gear, as that is their closest 1:1 ratio gear, so many shops don't know any better and will do 3rd gear pulls unless you tell them otherwise.
i never dynoed stock, so i can't really give any input as to what my numbers were. highest i've ever seen stock was 250 or so....
