blowing oil
Old Jul 20, 2006 | 09:34 PM
dragon111203's Avatar
dragon111203
Default blowing oil
we istalled my mopar bov todat everything was fine till i got home i am blowing smoke out the turbo we removed the oil line going to the turbo to get to the last bolt now its leaking and i thought we lined evrything up plus it is tight let me know people so i can fix it tonight thanks for everyones help
Old Jul 21, 2006 | 03:26 AM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: blowing oil
Those two bronze fittings are compression fittings. YOU CANNOT remove them without replacing them. You need new ones. Don't drive the car too much you'll risk blowing the turbo (mine were on wrong from the factory and blew mine, I would know). You can get them from the dealer really cheap.
Just go ask for the banjo fittings on the oil feed line to the turbo.
Never ever ever ever remove compression fittings. Once uncompressed, they leak.
Old Jul 21, 2006 | 05:16 AM
71RoadRunner's Avatar
71RoadRunner
Did you use thread tape or pipe dope before reattaching the oil line?
Old Jul 21, 2006 | 10:56 PM
dragon111203
so i need to replace it what will it do just leak oil or not get enough oil and can i realy use the tape for right now
Old Jul 22, 2006 | 11:52 AM
71RoadRunner
If I remember correctly it says that you may need to either disconnect that oil line to gain access to that bolt or gently pry the oil line away to allow bolt access. Before reattaching the oil line you need to put something on it's threads to keep it from leaking and I believe it's addressed in the instructions for the Mopar BOV.
Old Jul 22, 2006 | 08:02 PM
dragon111203
bought the bolt today installing it and i am good to go thanks for your help
Old Jul 23, 2006 | 03:32 AM
LilSparkPlug
Did you get those two little copper washer guys too? You need those more than the bolt. Let us know how you make out.
