Instillation Help..
Old Aug 9, 2006 | 01:12 AM
Racevette77's Avatar
Racevette77
Default Instillation Help..
Ok i searched the forums regarding manual boost controller instillation help....... NO one Answered the HOW DO YOU DO IT question. Was allways dont do this or that...........Now..
How do you install the boost controller??? What goes where?
I know its easy i just need some guidence im new to turbos so i dont know all the lingo and the lil attach ment things -- so pics or descriptions would help. I looked all over the web but could NOT find Anything regarding SRT4 instillation with or w/o picutres only Eclipse and Evos and ****.
Pls help im gettin tired of searching the web and finding nothing.
Old Aug 9, 2006 | 01:21 AM
winniep's Avatar
winniep
Default RE: Instillation Help..
Did you look on the "other" forum? (sorry, links are frowned upon)
Old Aug 9, 2006 | 02:48 AM
Racevette77
Ok after doing 2 hrs of reading different HOW TO's for OTHER cars ive come up with this....... Holla if im correct.
1) remove the hose off the wastegate (this hose goes to Top of the air box where the electronic shiz is and can be blocked off) =ing useless.
2) remove the hose that is under the Turbo Intake that connects to the air filter box.
3) block off the air box hole / hose.
4) connect the BC to the wastegate and run a line from the BC to the area where i previously removed the hose connecting to the air intake.
Sound correct?
Would LOVE some help............
Old Aug 9, 2006 | 02:59 AM
LilSparkPlug's Avatar
LilSparkPlug
I have an EBC so my setup is a bit different than yours, unfortunately I wouldn't be any help. I have lines removed that I belived an MBC simply ties into
(black line, blue line, green line)
