Diff Fluid
Old Aug 21, 2006 | 03:49 PM
rare04's Avatar
rare04
Default Diff Fluid
I'm going to be changing my diff fluid here soon. Any recomended type. Thanks
Old Aug 21, 2006 | 10:24 PM
Pressurecooker's Avatar
Pressurecooker
Default RE: Diff Fluid
Yes absolutely! Redline C-4 or C+4 or whatever they call it is all you need to know. It is synthetic, it meets all the requirements, it will slick up your box real good. It is not always easy to find, but can be gotten through anyone that sells Redline oils. You will need three quarts and it costs about 9.50 a quart. I'm telling you you can run it straight with no additives as I do or, you can add the Mopar recommended friction modifier as Everybody else on here will tell ya to. Either way, you'll be happy you used the Redline. You will feel the difference immediately. (and change it every year, it's easy to do)
Old Aug 21, 2006 | 10:39 PM
rare04's Avatar
rare04
thanks bro, I've got some on order.
Old Aug 22, 2006 | 03:33 AM
Andy4.7's Avatar
Andy4.7
I'm using the Amsoil ATF. Seems to work fine, maybe a slight improvement. Swapped out around 15,000 miles. My car has always shifted smooth IMO regardless so I don't know. I might try the redline or something else next change.
Old Aug 22, 2006 | 06:44 PM
Plan B's Avatar
Plan B
I'm running the Amsoil as well, but the Redline has sparked my curiousity... The Amsoil doesn't seem to be anything special at this point...
Old Aug 23, 2006 | 09:30 PM
street demon's Avatar
street demon
WHERE CAN I FIND THE REDLINE TRANNY OIL AT?
