how low is to low
Old Aug 29, 2006 | 10:28 PM
zukidragon's Avatar
zukidragon
Default how low is to low
I want the most in handling I can get, with a stiffer spring and the question is how low can I go. I do not want to change my camber, so is 1" in front and 1 1/2" in rear safe or can you go lower.
Old Aug 30, 2006 | 04:25 PM
LilSparkPlug's Avatar
LilSparkPlug
Default RE: how low is to low
Just buy the camber bolts. For how cheap they are, they allow the camber to be adjusted, which in turn will give you BETTER handling. Don't go the cheap way out just because you have to do something else to get it to operate properly.
Old Aug 30, 2006 | 06:35 PM
PSI Chick's Avatar
PSI Chick
you can go as low as you want as long as it's done properly. you're only too low when you're dragging on the ground!
Old Aug 30, 2006 | 07:17 PM
turbeaux kid's Avatar
turbeaux kid
With what I lowered my car with I think it was to low. In the first few days I hit a bump and the CV boots blew out. There are 4 and I blew all of them out.
Old Aug 30, 2006 | 07:36 PM
MEandmySRT's Avatar
MEandmySRT
When you start to hate driving your car, you're too low.
