what do yall do for winter tires?
Old Sep 18, 2006 | 02:16 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default what do yall do for winter tires?
are there any cheap steelie wheels for our bolt pattern? just wondering if i should get wheels/tires or just some snow and ice tires and put them on the oem rims.
Old Sep 18, 2006 | 03:55 AM
PSI Chick's Avatar
PSI Chick
Default RE: what do yall do for winter tires?
vw steelies and pt cruiser steelies work great, and come in a nice 15" size which is great for snow tires.
Old Sep 18, 2006 | 05:39 AM
Pressurecooker's Avatar
Pressurecooker
Regular Neon steelies WILL NOT WORK. They do not clear the brake caliper on the front wheel. Also, I believe tirerack.com had steel wheel and snow tire package. I personally put snow tires on my 16" aluminum rims. Though I am not crazy about subjecting aluminum to salt. The tire I use is a directional tread "Winterforce" tire that is sold at my local Firestone dealer. They do not handle like the summer tires, but they are great in the snow. I live in Michigan and had no traction issues all winter last year.
Old Sep 18, 2006 | 07:47 AM
moparman04's Avatar
moparman04
use the same tires... this is obviously not for us cali srt's
Old Sep 18, 2006 | 06:30 PM
flamingpinhead
Section Moderator
tirerack unfortunatly dosent have any steelies and im not paying for alums, ill get better summer rims and use the oem for winter first. but you say pt cruiser steelies will work? i realize the 14" neon steel rims are way too small. but i guess if 15s will clear the brakes, itl be the cheapest way to go.
Old Sep 18, 2006 | 07:11 PM
SRT_YA's Avatar
SRT_YA
I decided to buy a 2003 Ford Ranger 4x4... solved my tire problem on the Neon... HA-HA!
Old Sep 19, 2006 | 04:03 AM
Pressurecooker
ORIGINAL: flamingpinhead
I repeat, regular Neon steelies WILL NOT FIT. I tried the 15's, they will not fit. You have to go cruiser or v-dub. May not be easy to find but that's what you have to do. Or, like me, put snows on the aluminums. I could not find steels either locally. I will not by a steel rim from a dealership, as they are outrageously priced. More than my aluminums were! 'Course I got a smokin deal on my aluminum wheels.
Once more, steel 15" Neon wheels do not fit.
Old Sep 19, 2006 | 04:06 AM
PSI Chick's Avatar
PSI Chick
i've never tried to put a neon rim on, what doesn't fit? offset? bolt pattern?
Old Sep 19, 2006 | 04:37 AM
Pressurecooker
They are not deep enough and hit the front wheel brake caliper. I believe they will clear the back brakes ok, just not the fronts. I remember it was so close to working though as if a wheel spacer might be enough to push the rim away from the brake.
Old Sep 19, 2006 | 03:45 PM
whatneon's Avatar
whatneon
Discount tire direct sent me 15" steelies that do fit with goodyear snows for cheap.
