Cruise control
Old Jul 10, 2004 | 11:35 AM
fortywillys's Avatar
fortywillys
Default Cruise control
Any one know if the pt cruzer gt's cruise will retro fit on the srt. Or if it's possible to install it on the srt
Old Jul 11, 2004 | 04:53 AM
t0973mf's Avatar
t0973mf
Default RE: Cruise control
I don't know if this is true but someone said the turbo is in the way where the factory cruise cables on the neon's should be.
Old Jul 11, 2004 | 12:05 PM
glhs837's Avatar
glhs837
With enough mechanical ingenuity, it's possible to adapt it, but as stated above, you would have to redo the cables to the throttle body. And there does not appear to be a stock set that would just bolt up. Then theres the throttle body itself, which only has a place for one cable, unlike a car with cruise, which has two cable places.
And lastly, and what killed my dream of doing this. Stage 2 untilizes the PCM pins that you would need for cruise for some other input.
Go faster > Have cruise, for me anyway And I've put 36K on my car since Feb 03
Old Jul 11, 2004 | 11:12 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Cruise control on a SRT-4 is an oxymoron....[sm=smiley36.gif][sm=smiley20.gif]
