SRT4 required reading/all u wanted 2 know
Old Oct 12, 2006 | 06:30 PM
Vettely's Avatar
Vettely
Default SRT4 required reading/all u wanted 2 know
http://www.answers.com/topic/dodge-srt-4
DODGE SRT-4
Manufacturer: DaimlerChrysler
Production: 2003–2005
Successor: Dodge Caliber SRT-4
Class: Sport compact
Body style: 4-door sedan
Engine: 2.4 L turbocharged I4
Related: Dodge Neon
Similar: Ford Focus SVT
More information is available on the Dodge Neon page. See also the Dodge Caliber SRT-4.
The Dodge SRT-4 was a turbocharged sport compact introduced by DaimlerChrysler's Street and Racing Technology (SRT) in-house tuner group (originally known as PVO) in 2003. SRT stands for "Street and Racing Technology", and the "4" in the SRT-4's name denotes the number of cylinders it has. ACR and Commemorative Edition models were later introduced as well. The SRT-4 was designed for the racing and muscle car crowd, as well to attract younger buyers who had previously only considered owning Japanese sport compact cars.
2005 Car and Driver Supercar Challenge Front Wheel Drive Class Winner, a Dodge SRT-4 built by Howell AutomotiveThe SRT-4 differed from a Neon, the model on which it was based, in many ways. From the outside, the SRT-4's unique front fascia was immediately noticeable. It also featured a large rear wing, unique rear fascia, side skirts, unique hood featuring a functional hood scoop, and special 17x6 in wheels (16x7 on ACR model). Beyond asthetics, the SRT-4's entire powertrain, suspension, braking syestem, exhaust, and much of the interior differed from the Neon on which it was based.
Under the hood was a turbocharged 2.4 liter I4 engine. This engine first appeared in the United States one year earlier in the 2002 Chrysler PT Cruiser GT Turbo, but had been used in the Mexican-market Dodge Stratus/Chrysler Cirrus LXi sedan for a few years before this. The SRT-4 used a New Venture Gear T-850 5-speed manual transmission (pirated from the Graz-built turbodiesel minivan), equal-length half shafts, and a high-capacity Sachs performance clutch. The suspension used stiffer springs, special Tokico struts, larger sway bars front and rear, firmer bushings, an upgraded steering rack from the PT Cruiser GT, upgraded knuckles, and a unique K-member. 11.0 in (279 mm) vented disc brakes (with extra-thick rotors to prevent warping) were used in front, with 10.6 in (270 mm) non-vented discs in the rear.
Inside, the front seats featured enhanced lumbar and lateral support for performance driving, and a faux carbon fiber steering wheel and satin silver "cue ball" shift **** were used. The gauges had special SRT faces and silver rings matching those on the climate controls. An Auto-Meter brand boost gauge was used as well.
The 2004 model was updated with more power and torque, a torque-sensing Quaife limited-slip differential, larger fuel injectors, BF Goodrich KDW2 three-season, ultra-high performance tires, and paint and trim changes. 2005 also featured new colors, but the important news was the return of the American Club Racing (ACR) edition.This package included wider BBS RX lightweight racing wheels with wider tires, 5-way adjustable Tokico Illumina shock absorbers, a stiffened suspension featuring thicker front and rear sway bars, seats with pass-through slots for racing harness's, factory service manual-allowed camber adjustment, and ACR logos on the exterior and embroidered on the front seats. A limited edition, numbered, 2005 SRT-4 Commemorative Edition appearance package (in white with blue "Viper stripes") was also offered, but not with the ACR package.
Performance and Specifications
Curb weight: 2880 lb
Power: 215 WHP (2003 model), 230 WHP (2004-05 models).
Torque: 245 ft·lbf @3000 rpm (2003 model), 250 ft·lbf @2200 rpm (2004-05 models)
0-60 time: 5.3 seconds (Car & Driver)
1/4 mile time: 13.8-14.2 seconds (various magazine reviews)
1/4 mile speed: 98-102 mph (various magazine reviews)
Top Speed: 153 mph
Although the SRT-4 is rated at 230 hp (2004+), it was revealed that Dodge underrated the car's power production. Dodge tested the SRT-4 prototypes on the dyno with a fairly hot intercooler, which negatively affected overall efficiency. Most production SRT-4s in fact rate right around 230 hp at the wheels, therefore crank horsepower is estimated at 265-275 hp. This makes them fairly formidable versus much more expensive production sports cars in real world, "roll-on" situations from 30 mph and up.
In real world use, SRT-4's have run high 13's to low 14's at 100 - 105 mph in the quarter mile with a capable driver. The fastest documented stock (showroom unmodified) quarter mile time for a 2003 SRT-4 is 13.75 @ 101.68 mph, with a fastest trap-speed of 103.16 mph [1], while the fastest quarter mile times with documentation for more powerful 2004-2005 models include several 13.6's @ 105+mph. Those stock times included the use of the original, factory-equipped tires. Also, several modified, privately owned and driven SRT-4's have achieved 10 second 1/4 mile passes since 2005. See www.SRTforums.com for more information.
Of note asthetically, when Dodge was re-designing the SRT-4 pre-production model in late 2002 prior to its release, they added two nostrils on the front fascia to help with the upgraded cooling system, a revised boost gauge face, and standard pedals instead of the aluminum ones that would be used on later year's SRT-4's.
Engine block
Engine code: A855
Block construction: Cast iron, closed deck, split crankcase
Bore x stroke: 87.5 mm x 101.0 mm
Displacement: 2,429 cc
Compression ratio: 8.1:1
Bore spacing: 96 mm
Deck height: 238.14 mm
Pistons: Cast by Mahle, eutectic aluminum alloy
Connecting rod design: Forged, cracked caps, threaded-in 9 mm rod bolts
Connecting rod length: 151 mm
Rod/stroke ratio: 1.50:1
Crank design: Cast high-hardness steel
Main bearing diameter: 60 mm
Rod bearing diameter: 50 mm
Cylinder Head
Head construction: Cast aluminum
Combustion chamber design: 48-degree pent-roof with partial cloverleaf between intake valves
Valvetrain: Hydraulically adjusted rocker arm with roller cam followers
Intake valve size: 34.80 mm (Silchrome-1)
Exhaust valve size: 28.45 mm (Inconel)
Intake valve angle: 24.46 degrees
Exhaust valve angle: 23.5 degrees
The SRT-4 used the same block and head as the turbo PT Cruiser; however the intake manifold, turbo plumbing and intercooler are different. The intercooler is a front mounted cast aluminum 8-row unit produced by Valeo. The turbocharger is a reverse rotation Mitsubishi TD04LR-16Gk with a 6 cm² turbine inlet. Tight packaging forced some creative thinking on the turbo. The TD04 compressor has a compressor bypass valve built right into the compressor housing. The exhaust manifold and turbine housing are cast in one piece by Mitsubishi from high-nickel Ni-Resist steel. The one-piece design improves flow, reduces size and reduces thermal mass for quicker cat light-off. The turbine discharge is also part of the manifold/turbine housing casting, and it loops back around and hits the manifold again on its way to the catalytic converter. Where they meet, there's a wastegate valve. Keeping the wastegate valve away from the turbine housing improves flow where it matters most. Maximum boost in stock form is around 14 lbf/in² (97 kPa). This translates to 215 hp @ 5400 rpm and 245 ft·lbf torque @ 2000 rpm at the flywheel ( 2004-05 230 hp and 250 ft·lbf (339 Nm) torque now boosting 15 lbf/in² (103 kPa))Dodge under estimated these power figures as it has been proven on many occasions that these numbers are usually seen at the wheels.
Exhaust fumes exit through a catalytic converter, two resonators and a stainless steel mandrel bent 2.25 inch exhaust piping system, which splits into two at the rear with no mufflers, for a distinct sound.
Paired with the SRT-4’s turbo-charged power plant are a New Venture Gear (NVG) T-850 high-performance 5-speed manual transmission, equal-length half shafts and a Sachs high-capacity performance clutch and pressure plate.
Suspension is rounded up with 170 lb F / 125 lb R springs, specially valved Tokico struts, 24 mm front / 17 mm rear sway bars (Larger sway bars are available through Dodge parts. a 26 mm bar for the PT cruiser convertible and a 19 mm rear bar from the Neon ACR can be ordered, and is standard on the SRT-4 ACR), firmer bushings, quicker ratio steering rack from the PT GT, upgraded knuckles and a unique K-member.
Blending power and control was made possible by the interaction between the Dodge SRT-4 development team and performance operation engineers who cut their teeth in Sports Car Club of America (SCCA) racing. Braking consists of an ABS system with 11.0 in (279 mm) F vented/ 10.6 in (270 mm) R discs and single piston calipers (57 mm F/ 36 mm R).
17x6.0 (45 mm offset) cast aluminum wheels coupled with 205/50/17 Michelin Pilot Sport tires help put the power to the ground on 2003 models, with 2004+ models getting BF Goodrich KDW2 tires. Even wider 225/45/16 BF Goodrich KDW2 tires on lightweight BBS racing wheels (40 mm offset) were offered on the ACR model in 2005. The expressive standard 17x6 wheels were purposely designed to look like aftermarket wheels, and the unique spoke pattern allows for better airflow to the brakes. The design shows much similarity to the TSW VX1 wheels found on the 2001 concept supercharged Neon S-R/T.
External key features
On the outside, performance cues start up front where a new front fascia and a unique steel hood with an integral air intake that perches, ready to cool the powerful 2.4-liter turbo engine. Just behind the lower grille sits a cast aluminum intercooler. The taller, basket-handle type spoiler also improves vehicle handling by generating downforce and providing a stabilizing effect at high speeds.
Inside the cabin, taking cues from the seats in the Dodge Viper SRT-10, the SRT-4 front seats have enhanced lumbar and lateral sections for better support during racing-type maneuvers. The new Agate-colored cloth on the body of the seats is textured for better grip through the corners. The side bolsters of the front seats are trimmed in vinyl and curve to stabilize occupants, further enhancing the performance racing feel of the vehicle. The car's rear seats also feature the textured fabric.
A new carbon-fiber-look leather wraps the top of the SRT-4’s steering wheel for greater control. A satin silver cue ball shift **** tops a shifter that is surrounded by a boot made of the same textured carbon-fiber-look leather as the steering wheel. The steering wheel's unique three-spoke design also provides a better view of the instrument cluster gauges.
Unique gauge designs in the SRT-4 (which are exclusive to the SRT lineup) feature special silver faces with satin silver ring accents. The same satin metal trim also is featured on the instrument panel center stack, around heater, ventilation and air conditioning (HVAC) ***** and on door handles. A silver Auto-Meter brand turbo boost/vacuum gauge is to the right of the instrument cluster. The temperature gauge also plays an active role in monitoring the cars vitals. It is very functional piece unlike most other modern cars in which the temp. needle never moves, staying in the middle of the range while coolant temperature rises and falls as much as 40 degrees. However in the SRT-4, drive fast and the needle climbs, cruise and it falls.
Along those lines, the SRT-4's boost/vacuum gauge finds a convenient spot underneath the brow just to the right of the instrument cluster. Unlike aftermarket gauges, the SRT-4 turbo gauge has been thoughtfully incorporated as a design element of the brow.
The SRT-4's roots come from SCCA racing. Dodge intended a package of performance, styling and quality at a low cost, and has shown what the SRT-4 is capable of in motorsports, campaigning the SRT-4 in Rally, SCCA and drag racing circuits, with much success.
The 2004 model received some much needed enhancements which included the following below.
New torque-sensing limited-slip differential developed jointly with Quaife
Power increased to 230 hp (172 kW) at 5300 rpm and torque increased to 250 ft·lbf (339 Nm) between 2200 and 4400 rpm
New NGC3 engine control module and a new calibration for wider torque range
Mopar Stage 1 Larger fuel injectors provide increased fuel flow
New BF Goodrich KDW2 three-season tires are standard equipment
Developed to match the vehicle’s high-performance suspension and handling characteristics, the new tire’s design and rubber compound provide maximum grip for cornering, accelerating and braking
Unique racing-inspired bright pedal pads added
Optional sunroof with passenger assist handles
Electric Blue paint replaces Solar Yellow
Chrome trim replaces the black trim on the headlamps
The 2005 model received a few new colors: Orange Blast which replaced Electric Blue, and Stone White which replaced Bright Silver Metallic halfway through the 2005 model year. The second half its final (2005) model year also included the return of the ACR nameplate to the Dodge line-up, with the package available only on the SRT-4.
SRT-4 ACR
This factory competition version, which stood for "American Club Racer", included:
Wider, light-weight 16x7 inch BBS RX racing wheels with 40 mm offset
Wider 225/45/16 BFG KDW2 tires
one inch lower ride height
5-way adjustable performance Tokicko Illumina dampers (gas shocks)
Thicker front and rear sway bars
Stiffer rear tension strut bushing
ACR embroidered, Viper-styled, racing seats with pass-throughs for a racing harness
ACR decals on the bottom of the front doors
Full-size spare with accompanying ultra-high performance tire
2005 Commemorative Edition
Also for 2005 was the SRT-4 Commemorative Edition. This model (along with the SRT-10 Viper and Ram) was created to celebrate the excitement, power and performance that SRT vehicles bring to the road. The limited, numbered edition SRT-4 included the extra appearance options below. (No performance extras are added on the Commemorative Edition):
Electric Blue "dual fang" racing stripes over the Stone White body color
Blue accent stitching on the seats, floor mats, shift boot and steering wheel
Stainless steel door sill plate
Commemorative Edition Production Number
References
Allpar
DodgeBoy
See also
Dodge Neon
Old Oct 12, 2006 | 11:39 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: SRT4 required reading/all u wanted 2 know
its sooo sad they stopped making them
Old Oct 13, 2006 | 12:24 AM
Four Banger Anger's Avatar
Four Banger Anger
thats awesome, it is sad they stopped making them, but hey I dont think i will ever get rid of mine because of how rare they are geting...especially up here in canada, theres barely none!!!
Jordan
Old Oct 13, 2006 | 02:33 PM
Vettely's Avatar
Vettely
I added the link to the top of the article. http://www.answers.com/topic/dodge-srt-4
Yep, after reading that i felt "proud" to drive a neon. Actully this article makes you realize the large amount of differences between our SRT4's and regualr neon platforms.
Old Oct 16, 2006 | 02:14 AM
Pressurecooker's Avatar
Pressurecooker
Very cool. I am going to cut and paste this into my local forum.
Thanks.
