VEI Boost gauge
I see Glacial graphics sells a digital VEI turbo boost gauge. Does anyone know if this is a straight replacement for the stock boost gauge ? Is it more accurate than the stock gauge ? The stock gauge is hard to read when you're concentrating on steering, shifting and watching the tach.
I have it. Its way more accurate than stock. It can be annoying to read when its flipping between numbers, but other than that its killer accurate. The only modifications needed are to expand the holes in the boost gauge pod a bit so that the bolts will fit through, and
