which line to the turbo?
Old Nov 17, 2006 | 06:36 PM
talisman's Avatar
talisman
Default which line to the turbo?
I've got a 2005 Stage 1 with a Stage 2 WGA and some other mods, which line should I be running to the WGA ? Black or Green ? Which has less spike ?
I adjusted the WGA today to 3 mm preload and it's still spiking to 18, maybe 19, hard to tell on the damn gauge. I'd like to keep the spike around 17 and hold 14-15.
Should I adjust the preload down further ?
I had a flatspot in the acceleration about 5000 RPM's before adjusting the WGA, that seems to be gone now (pulling timing maybe ).
I have a Turbo XS MBC to put on later once I get this WGA adjusted properly.
Old Nov 17, 2006 | 08:23 PM
Burnnout's Avatar
Burnnout
Default RE: which line to the turbo?
How much boost are you holding right now ? ... basically that's all to be concerned with while just running the WGA ... the MBC is what you're going to want to control the spike with.
Old Nov 17, 2006 | 08:27 PM
talisman's Avatar
talisman
It's holding 15-16 in 3rd, 4th and 5th.
Old Nov 18, 2006 | 11:15 AM
Burnnout's Avatar
Burnnout
If you are holding 15-16 I wouldn't mess with the WGA , just hook up the MBC and use that to bring the spike where you want it.
Old Nov 18, 2006 | 05:36 PM
PSI Chick's Avatar
PSI Chick
set the wga to about 12-13psi off the green line then bring the boost up the rest of the way with the mbc. that will give you the least amount of ptb and spike.
