Oil catch can HELP PLEASE
Old Nov 27, 2006 | 12:24 AM
05SRTStage3's Avatar
05SRTStage3
Default RE: Oil catch can HELP PLEASE
Thanks alot and I am very sure that I have atleast 1 boost leak. How do I do a boost leak check. Maybe a stupid ? but I do need to know. And I ordered an OCC not the $20 one.
Old Nov 27, 2006 | 12:50 AM
YeahItsAHemi345's Avatar
YeahItsAHemi345
ORIGINAL: 05SRTStage3
Get a boost leak checker.
You can get one from a vendor or make your own.
Old Nov 27, 2006 | 12:52 AM
05SRTStage3
Where can I get a boost leak checker....or were you just joking?
Old Nov 27, 2006 | 01:15 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
just run a search, i know there is a step-by-step how-to on this. and its very inexpensive to make. not sure if it was on here or 'the other forum'
Old Nov 27, 2006 | 02:14 AM
05SRTStage3
And wil the boost leak checker tell me where the leak is coming from.....and I have no smoke coming from the car so I know that I don't have a blown turbo seal...thank God...but I do know that I have an oil leak but I don't know where it is coming from...its dripping from the hot side pipe that is next to the oil filter. It only leaks while boosting....And where the oil leak is coming from that is more than likely where the boost leak is coming from. But I have no freaking idea from where!
Old Nov 27, 2006 | 02:16 AM
flamingpinhead
Section Moderator
the leak detector will only tell you that you have a leak. to find it youll need to use sense of touch/sound (and the buddy system) to find it
