15" Rims anyone?
Old Jul 27, 2004 | 06:47 AM
JDaniels's Avatar
JDaniels
Default 15" Rims anyone?
Okay, I have seen/heard of a couple people mentioning 15" rims that are available for our cars, that will fit over the brakes. If anyone happens to know the manufacturers/models, and could pass that info along, that would be great. I would also like to know if there is a specific backspacing/offset required on them, or if that's just how they come period.
Thanks-
Old Jul 27, 2004 | 05:44 PM
PSI Chick's Avatar
PSI Chick
Default RE: 15" Rims anyone?
the rim needs to have a 35mm offset to clear the calipers. people are using 15" rims for drag radials and slicks, i don't know anyone that uses them as daily drivers. the kosei k-1 is very common to use, as are the pt steelies. there are other 15" rims that will fit, but the kosei is the lightest that has a decent price, which is why people like them.
Old Jul 28, 2004 | 05:17 PM
mjsaidler's Avatar
mjsaidler
N E 1 know a good place to get the Kosei K-1's from?
Old Jul 28, 2004 | 07:09 PM
JDaniels's Avatar
JDaniels
well, after searching a bit, I need to ask another question. There are kosei k-1, and kosei k-1 TS now. I'm guessing that you're referring to the older 5'star series, http://www.tirerack.com/wheels/Displ...Silver+Painted, or are you referring to the TS - http://www.gomiata.com/koseik1ts.html
the TS mentions that it has a 38mm offset, so it looks like it'd be fine, just checking to see.
Old Jul 28, 2004 | 07:15 PM
PSI Chick's Avatar
PSI Chick
the older series is what people use, tirerack has them for $129 each.
