Rough Idle
Old Nov 29, 2006 | 08:18 PM
aalva79's Avatar
aalva79
Default Rough Idle
Hi all, i have recently changed the spark plugs on my baby because i just installed quite a few mods but the idle seems a bit too rough for new plugs. The recent mods were the stage 2 w/o toys, E.D. hard pipes, HKS BOV, and block off plate. So, last weekend i changed the oil and decided to go with new spark plugs (NGK Iridiums at .035) as well and the idle after the change felt a bit more rough than usual, could i have a defective spark plug or maybe bad plug wire ( wires are MSD). Under WOT, it feels fine and slow driving is no problem at all, but its when i come to a stop and idle that it just seems too rough. Could i be worrying too much or what else can i check, i also recently installed the MPx Heat shield to help a little, which i had posted a few days ago.
Thanks guys any and all help is appreciated.
P.S. Sorry for making my post so long[sm=boink3.gif]
Old Nov 30, 2006 | 04:52 AM
PSI Chick's Avatar
PSI Chick
Default RE: Rough Idle
.035 is a little low for an irridium, might want to raise that some. be careful, the electrodes break easily. what's your psi levels?
Old Nov 30, 2006 | 12:42 PM
hozay@N2MB's Avatar
hozay@N2MB
I have my Iridiums at .029 but I have stg 3 w/ bolt ons. Any higher and I was experiencing spark blow out. Sounds like more to this story then just plugs.
Old Nov 30, 2006 | 02:40 PM
aalva79's Avatar
aalva79
thanks for the reply guys psi iam hitting 17 to 18 and holding pretty solid, but hozay the problem started after i changed the sprkplugs and ive heard 35 is the norm for higher performance cars gap. But to end this thread i took them out again and 2 of them were a little off like at 38 but i got them all to 35 and seems to a lot smoother now. I will let u guys know if this solved the problem.
Thanks guys and gals!!
PS hey psi what do u have your car spark plugs set at?
Old Nov 30, 2006 | 11:49 PM
05SRTStage3's Avatar
05SRTStage3
And also if the stage 2 replaced your injectors and fuel rail...if i remember correctly it does....if you read the manual there is a warning about the "fuel line pulse" my stage 3 idles a little rougher but not that bad...it is actually the fuel line pulsing if you listen to it and feel the vibration it will have a very constant and smooth rhythm....try this
Old Dec 1, 2006 | 03:24 AM
LilSparkPlug's Avatar
LilSparkPlug
She has entirely different plugs than all of us, gapped differently to support the setup that her car runs. The closer you gap them you will get a slightly rougher idle. But making sure that they're all gapped the same is key.
Old Dec 1, 2006 | 02:52 PM
aalva79's Avatar
aalva79
thanks guys and 05srt the stage 2 only replaces your injectors.
Old Dec 1, 2006 | 03:05 PM
connsrt's Avatar
connsrt
I had the same problem with my 04 but it wasnt spark you need to check your throtle sensor it is a harness under your intake and my wires were frayed and was giving off different readings it bucks really hard when your almost at a stop right
