stage 2 question
Old Jul 29, 2004 | 12:30 PM
glhs837's Avatar
glhs837
Default RE: stage 2 question
Y'all are forgetting the most important thing about that pretty red switch.
It seems to make folks yell "WooooHooooo!!!!, Holy Carp!!!!!!" "Mwahahahhahaha!!!!"
Old Jul 29, 2004 | 07:38 PM
Gargoile's Avatar
Gargoile
One thing I found about the Race Gas switch... Every time you turn off your car, it resets the switch ot OFF. Found this out the hard way....I was in the staging lanes and turned the switch to ON then moved up a few spots, then turned off the car. I didn't notice the switch was off till 1/2 way down the track. Reached over and hit the switch and it was like have the dial-A-boost #4. You can feel the power in the Butt-O-Meter.. Whooo HOOOOOO. Plus, I was running Purple Gas, rated at 114
Old Jul 30, 2004 | 04:06 AM
71RoadRunner's Avatar
71RoadRunner
That stuff must be leaded then if it's purple and 114 octane. I run 110 octane CAM2 leaded race gas in my Roadrunner and it too is purple. Don't use the leaded gas very often or you will need to replace the O2 sensor as well as the cat, that is if your running it with a cat at all.[sm=smiley2.gif]
