Spark plugs and motor mount ???
Old Dec 6, 2006 | 04:23 AM
Kartman38's Avatar
Kartman38
Default Spark plugs and motor mount ???
I got a stock srt 4, what plugs should I buy for the car and what gap should I set them at.. Plus Iv been hearin of some people stock motor mounts breakin.. should I be worried with stock power or what?
Old Dec 6, 2006 | 12:49 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Default RE: Spark plugs and motor mount ???
Everyone seems to like NGK 4306's. I have mine gapped at .40 but I believe as long as they're gapped from .35 to .45 you'll be okay. As for motor mounts...the stock ones SUCK even with stock power. Invest in some inserts or just buy some dog bones.
Old Dec 6, 2006 | 11:55 PM
Kartman38's Avatar
Kartman38
I started to get on it today in the car and it kinda cutted out.. I still have the stock plugs and wires in it... plus when i was ideling it was not as smooth as regular.. but it wasnt too bad... do u guys just think its the plugs and wires or somethin else i should be worried about???
Old Dec 7, 2006 | 12:20 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
bad plugs/wires will def. cause an unusual idle and lack of power (overgapping can cause the spark to blow out and buildup can prevent it from sparking) my wires got replaced at around 15k. i would invest in some new plugs and msd wires. even if its not the issue, it couldnt hurt. what mileage are you at?
Old Dec 7, 2006 | 12:27 AM
Kartman38's Avatar
Kartman38
22K as of now.. do u think thats the problem tho.. and the cars stock so what plug should i get and gap?
Old Dec 7, 2006 | 03:21 AM
PSI Chick's Avatar
PSI Chick
ngk 4306 gapped at .045 should be good for you
Old Dec 7, 2006 | 03:16 PM
flamingpinhead
Section Moderator
yeah, i gapped mine at .40, and im basically stock
