anyone else had leaking windsheild or rear window
when my car is parked facing down hill after a good rain storm, when i go to back up ill have a stream of water coming in on the passenger floor board. its like it collects in the plastic peace that holds the windshield sprayers and comes in thru the vents. also whenever it rains ill have a rear passenger door full of water it seems. i have to open the door and itll run out after a few minutes. was this a manufacturer defect or am i the only lucky one???
i once got water in the rear door. not sure how, neverhappened before nor ever thereafter. my wife said the door sounded weird shutting. here there was water inside of it. i pulled a little rubber piece on the bottom and the water drained out.
i know the neons had a little issue with the tail lights leaking into the trunk, but as far as water inside of the car? i think your the lucky one
There have been a few others on here in the past few years reporting water leaks thru the vents when parking on hills..........
Dusty
Dusty
do you guys know if that would be covered under the warranty. also i my belts are squeaking a little, especially when cold outside or on a day like today when its warm but very humid and muggy. could i get dodge to look at that as part of the warranty?
