bov
Old Dec 15, 2006 | 07:16 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
Default RE: bov
least money is the mopar plate. you dont need the blockoff plate for it, nor do you need any new pipes or adapters for it. just the 60 for the plate and your time installing it. all you do is remove the stock surge valve (3 bolts), insert the blue plate and put the stock back on. the only hard part is getting to it.
here is some discussion on it:
http://www.srtforums.com/forums/arch...hp/t-8819.html
this is a picture how-to for the mopar BOV:
http://planet1041.com/BOV/frame.htm
Old Dec 15, 2006 | 07:24 PM
jac05srt4's Avatar
jac05srt4
Default RE: bov
if you are looking for quick and cheap, then you need to go with mopar. it sounds cool, but everyone is different in their liking. it doesnt add performance, but is way cheaper than buying adaptors and stuff.
Old Dec 15, 2006 | 07:30 PM
flamingpinhead
Section Moderator
Default RE: bov
any way you choose to go with this, youll need to remove the stock surge valve, and i highly reccomend removing the battery tray, it will save you a lot of headache.
Old Dec 15, 2006 | 08:23 PM
04blksrt's Avatar
04blksrt
Default RE: bov
the bov(mopar) will be here tomorrow morning. is there anyone out there that has put this thing on that might possibly give me their # for me to call incase i run into any type of problem...also going to attempt to build the occ...ive got the directions, but still not confident in the install....promise im not some crazy person and i would be very very appreciative of any help!
Old Dec 17, 2006 | 11:40 AM
redevil's Avatar
redevil
Default RE: bov
if you want something cheap and fast to install...Mopar Bov or AGP Bov.If you want the coolest Bov in the world, go for the Godzilla Bov...goes for about $350..yeah i know expensive but you can forget about leaks and many more headaches. HKS isn't that bad, just make sure you buy the hard pipe kit, makes a difference
Old Dec 17, 2006 | 11:42 AM
redevil's Avatar
redevil
Default RE: bov
oh and those you see on ebay that go for about $120 for the whole kit inlcuding hardpiepes and plate are fake, HKS alone goes for 150
