coil pack
Old Feb 18, 2009 | 11:50 PM
phiklack's Avatar
phiklack
Default plugs
I shop at www.modernperformance.com and I bought some NGK Iridium plugs the colder heat range which I think was a mistake because I have a stock turbo. it caused my engine to sputter at low rpm's. I switched back to the champions and all was ok. do you gap the NGK plugs to .050 or .035 - .038?
I'm shure you have a bigger turbo w/more boost. what should i gap at? also I just replaced a crank case vent hose that was running to my catch can and that may have fixed my miss problem. I am going to try to get it to act up for the next two days. Thanks again for all the help.
Old Feb 26, 2009 | 12:30 PM
phiklack's Avatar
phiklack
Took my car to the dealership and they replaced the coil pack under warranty. they said it was weak and causing a missfire on #1. Has any one tried a Granitelly coil pack or are they as bad as the MSD. Thanks to all that helped.
Old Feb 27, 2009 | 10:58 AM
PSI Chick's Avatar
PSI Chick
keep the stock coil pack. why change it when it works perfectly fine
Old Feb 27, 2009 | 04:08 PM
mxrnick's Avatar
mxrnick
yea the stock one is good to at least a 1000hp so untill you get there dont worry about it.
Old Feb 27, 2009 | 08:11 PM
phiklack's Avatar
phiklack
Thanks everyone and keep it Mopar.
