oil build up on fmic tubing
Old Dec 19, 2006 | 02:07 AM
MAssSrTdriven's Avatar
MAssSrTdriven
Default oil build up on fmic tubing
when i changed my oil the other day i noticed there was oil build up around the outside of the lower tubing towards the driver side. i have no idea why oil would be there? is there oil leaking through into the intercooler? i didnt disconnect the tubing so idk whats in there but its was fresh oil and it was around the tubing idk if its leaking or what? what should i do to fix this
Old Dec 19, 2006 | 02:38 AM
Kartman38's Avatar
Kartman38
Default RE: oil build up on fmic tubing
do u have a catch can on urs?
Old Dec 19, 2006 | 02:52 AM
PSI Chick's Avatar
PSI Chick
oil blowby from the pcv valve. get a catch can.
Old Dec 19, 2006 | 03:13 AM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
put on an OCC. i guess if your motivated its now time to take off you FMIC, coldsideand intake manifold and clean away
Old Dec 19, 2006 | 03:32 AM
71RoadRunner's Avatar
71RoadRunner
Mine is the same way, as is most other SRT-4's, since i didn't get an OCC right away after getting my SRT-4. It would take quite awhile before the oil gets as far as the intercooler, so just install an OCC and then it won't be an issue.
Old Dec 19, 2006 | 11:55 AM
redevil's Avatar
redevil
I've been trying to buy one of those evercince i got my car....but i keep buying other stuff
Old Dec 19, 2006 | 12:54 PM
MAssSrTdriven
thanks alot for the info! i guess that will have to be my first mod [&:]
