-04blksrt-read this
Old Dec 30, 2006 | 12:18 PM
redevil's Avatar
redevil
Default -04blksrt-read this
hey man I couldn't get those damn pics printed so I couldn't get together with my friends.But I figured out where that blue line goes in my car, and yes it's blocked.Call me when you get a chance so i can show you.Also look at the right end of the little rubber pipe where that blue line is connected, looks like there's a rubber thing blocking it in the very end, thats what I need you to buy, but the whole pack so you can get diff sizes(they are cheap), then call me and I'll tell you how to block that blue line.Hopefully this will help, if not put the blue line back and I'll try to figure out what to do next, but I'm sure my friends will figure it out.My bov looks like it bent a lil' bit more the other day, now I got an even bigger boost leak, I ordered the Raptor bov with hard pipe kit yesterday so goodbye boostleak.Dude that kit is sik!!!!comes with hardpipe,block off plate,vac hoses,clamps and of course Raptor bov.It only goes for $324(shiping included), **** raptor bov alone goes for about $260.I got the hot side pipe that goes on the bottom of the car hooked to the inercooler, because i think I might have a boost leak there too, it was only $50 on ebay.It usually goes for about $90 or so.I still think you should get that AGP WGA, once you get that all your problems will go away, **** mine did, and I was running just like you.It's only $150, or you might find it at srtforums.com for about $80.Well dude I'm at work right now,call me when you're ready to roll so we can get that damn beast boosting again!!![:@]
Old Dec 30, 2006 | 08:39 PM
jac05srt4's Avatar
jac05srt4
Default RE: -04blksrt-read this
the problem you are having is what mine has been in and out of the dealership for this past month. i bring it in wednesday for the 4th time. they are replacing the boost gauge. they have replaced the wastegate and all the vac lines on the motor. they also supposedly tightened all the connections. but i have been having that horrible noise at low rpms and boosting 8. if this isthe fix iwill let you know.
Old Dec 31, 2006 | 09:39 AM
redevil's Avatar
redevil
most dealerships return you car in low boost, they don't know **** about srt4s.When mine messed up I got together with my friends and we fixed the problem in less than a day.
Old Dec 31, 2006 | 06:00 PM
PSI Chick's Avatar
PSI Chick
ever heard of a pm?
Old Dec 31, 2006 | 07:03 PM
talisman's Avatar
talisman
Thank you PSI. I was wondering if it was just me,,,,lol.
Old Dec 31, 2006 | 09:37 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
One's a newbee, the other should know better.......
Dusty
Old Jan 1, 2007 | 09:42 AM
redevil's Avatar
redevil
i did pm him but he wouldn't answer, just wanted to make sure he saw it.Come on guys I'm just trying to help him out,beisdes it's not like this forum has a limited amount of posts per user....so stop busting my *****!!!!!!!![sm=boohoo.gif]
Old Jan 2, 2007 | 11:53 AM
04blksrt's Avatar
04blksrt
sorry red....this is my first time to get on since friday. ill give you a call in a little bit so you can explain what it is that i need to do while im looking at it. sorry everyone.....im not sure how the pm thing works. red THANK YOU so much for actually takin the time to try and help...if this work ill mail you a check or something!!!!! HAPPY NEW YEAR EVERYONE!!!!!!!!
Old Jan 2, 2007 | 12:19 PM
redevil's Avatar
redevil
lmao...a check...I'll take a money order instead, a lot safer!!!.Now please tell me you bought the blocking rubber things!!!!!!!!???without those I can't do much!
Old Jan 2, 2007 | 12:44 PM
04blksrt's Avatar
04blksrt
dude ive been moving in my new place all weekend. i didnt even have time to get gas let alone pop my hood and do some work. however i may have some time to mess with it tonight or tomorrow. i will go by and get those blockers and then give you a call....i may actually call you while im there so i can make sure i get the right ones. ill call you in a little bit so we can actually "talk" about it....give me time to respond today cause i actually have to do some work today.....but ill be checkin back in periodically
