oil leak
Old Jan 4, 2007 | 08:51 PM
deepseastetson's Avatar
deepseastetson
Default oil leak
there is oil coming from the pipe going from the inercooler to the intake manifold. i was underneth checking out some things and i noticed the leak. the oil is dripping where the hose meets the inercooler
Old Jan 4, 2007 | 10:28 PM
dustyloins's Avatar
dustyloins
Hall of Fame Member
Default RE: oil leak
You don't have an oil catch can, do you.............that'sa common place for blow by oil to collect if you don't run an OCC.........
Dusty
Old Jan 5, 2007 | 12:20 AM
deepseastetson
I thought maybe a seal was leaking or something. whats an oil catch can is there suposed to be oil down there?
Old Jan 8, 2007 | 02:10 AM
thump_thump's Avatar
thump_thump
if ur running an aftermarket bov it is common for oil to be dripping around that area. the occ just reroutes the oil back into ur engine instead of leaking/spreading it around the ic hose
Old Jan 8, 2007 | 08:22 AM
talisman's Avatar
talisman
The "catch" can does just what it say's. It cathes the oil and holds it before it gets into the throttle body and intercooler. It installsin the line from the pcv valve to the throttle body.
