change the color of gauges
Old Jan 5, 2007 | 08:21 PM
srtbris's Avatar
srtbris
Default change the color of gauges
does anyone know how to change the color of the stock gauges in the car.including the boost gauge
Old Jan 5, 2007 | 08:31 PM
PSI Chick's Avatar
PSI Chick
Default RE: change the color of gauges
pull the dash off and remove the cluster. it takes 921 led's, blue work the best.
Old Jan 5, 2007 | 08:43 PM
srtbris's Avatar
srtbris
where can I get them autozone, pepboys are they common does that include the boost gauge
Old Jan 5, 2007 | 08:45 PM
PSI Chick's Avatar
PSI Chick
yea that includes the boost gauge. once you take the gauge out of the pod (there are two screws holding it from the top) just twist out the led and put in a new one. just remember that led's are directional, so before you screw everything back together turn things on and make sure your bulbs are in the correct way and working.
the bulbs can be found mostly anywhere. if you go to autoluminations.com they have a kit with all the bulbs in it you need to do the dash and gauge.
