agp wastegate install?
Old Jan 6, 2007 | 06:24 PM
98srt4screamer's Avatar
98srt4screamer
Default agp wastegate install?
Ok i inderstand how to install the piece and tune the wastegate but, my problem is that i dont know which line to "T" into the blue or green and after i "T" into whichever one then what do i do with the origional balck hose on the stock wastegate?I dont have s1 on the car right now if that makes a difference. any help appriciated, tim
Old Jan 6, 2007 | 06:56 PM
PSI Chick's Avatar
PSI Chick
Default RE: agp wastegate install?
run it off the black line until you put s1 in, you'll end up with a overboost code otherwise. once you do switch lines though, use the green line and either rip out or cap the black line.
Old Jan 6, 2007 | 07:04 PM
98srt4screamer
alright thanks psi. to the rescue again
Old Jan 6, 2007 | 07:13 PM
PSI Chick's Avatar
PSI Chick
glad to help
