what can it be??
Old Jan 15, 2007 | 06:16 PM
moparman04's Avatar
moparman04
Default what can it be??
okay its been awhile since ive left a post. sorry guys...
well here is my problem, im throwing a p1188 ( tip sensor performance )
i check the green line running to the back of the turbo and it is connected...
my car is detonating bad.. idles fine runs fine unless i go full throttle... its not ptb for sure. i have that and know how it feels.
my mods consist of...
stage 2 wastgate
cat delete
exhaust
intake... and thats it i dont have my stage 2 anymore
any ideas???
Old Jan 15, 2007 | 06:46 PM
redevil's Avatar
redevil
Default RE: what can it be??
you mean when you floor it it runs good for a couple of secs and then something goes boom and slow the car down, then you pick up speed again?if thats the case then you must be boosting too much and there is not enough fuel.Mine does it, so I bought a fuel pump, it helped one of my friends, who had the same problem...it should get here on wednesday
Old Jan 15, 2007 | 07:38 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
ORIGINAL: moparman04
stage 2 wastgate
cat delete
exhaust
any ideas???
So, your running a stage 0 pcm with WGA and no cat?
If so, that's your problem. Get a staged pcm!
Old Jan 15, 2007 | 08:00 PM
PSI Chick's Avatar
PSI Chick
plugs and wires
