Boost Problem Help..?
Old Jan 19, 2007 | 12:20 AM
BLKSRT4's Avatar
BLKSRT4
Default Boost Problem Help..?
Ok so when im driving normally my boost goes from like0 psi and drops close to -20, when keeping at a steady pace like 35 mph. And while im driving hard ill step on the gas, and my boost spikes to about 14 and then will fluxuate between 10 and 11. And the needle is bounces up and down. between 11 and 10.
Is that a problem maybe boost leak? or is that just normal just some inciet please
Old Jan 19, 2007 | 01:37 AM
thump_thump's Avatar
thump_thump
Default RE: Boost Problem Help..?
sounds like u have a boost leak... i had the same problem. do u have the stock bov? or aftermarket?
Old Jan 19, 2007 | 04:22 AM
BLKSRT4's Avatar
BLKSRT4
Yeah i have a mopar BOV. Im guessing its near the BOV. Cause i want all my darn boost...
Old Jan 19, 2007 | 01:15 PM
thump_thump
well for one-- mopar bov are not too reliable so ur problem could be that ur bov is leaking under high boost. they do sound good but dont perform well.
Old Jan 19, 2007 | 03:45 PM
YeahItsAHemi345's Avatar
YeahItsAHemi345
Take off your mopar BOV and put some RTV sealant around the gasket and the surgevalve. If you have a boost leak tester then perform a test.
Old Jan 19, 2007 | 09:54 PM
BLKSRT4's Avatar
BLKSRT4
I dont have a boost leak tester. So you guys think its the actual BOV. Cause i was planing on buying a raptor with a pipe. So the blocking plate will go where the BOV is at. Will i still need to use sealent?
And today i just bottom'd out really hard. And now im only pushing like 10 lbs i hope i didnt break anything or knock anything loose....
BTW my friend just bought a turbo kit for his car and now he is going to push 500 hp .... im going to kill him...[:@]
Old Jan 19, 2007 | 10:07 PM
BLKSRT4's Avatar
BLKSRT4
And how do you use a boost leak tester where do you hook it up at?
Old Jan 20, 2007 | 03:30 PM
YeahItsAHemi345
ORIGINAL: BLKSRT4
Your BOP (block off plate) should come with a gasket, if not then use some RTV sealent. The BOP will go where your surge valve and Blue plate currently are.
Find the "how-to" on building your own boost leak tester (it's easy). You'll have to remove your intake pipe and hook the tester up to your turbo inlet. Use a air pump to build up some pressure and listen for leaks....and so on....
ORIGINAL: BLKSRT4
Your IC (inner cooler) pipe got knocked off or loosened up. Re-clamp them.
Old Jan 20, 2007 | 04:11 PM
BLKSRT4's Avatar
BLKSRT4
you know what you guys are alot of help. And is there anyway that the intercoooler could be cracked and that might be my problem?
