Injectors
Old Jan 25, 2007 | 01:32 AM
manninej's Avatar
manninej
Default Injectors
Are these sufficient for Stage 2 with Toys?
http://www.srtforums.com/forums/showthread.php?t=325603
Old Jan 25, 2007 | 04:28 AM
PSI Chick's Avatar
PSI Chick
Default RE: Injectors
yea they'll work
Old Jan 25, 2007 | 02:12 PM
blacksrtinAZ's Avatar
blacksrtinAZ
yes but without a fuel contoller you'll be running rich
Old Jan 25, 2007 | 02:15 PM
PSI Chick's Avatar
PSI Chick
no richer than s2 would have you normally run
Old Jan 25, 2007 | 02:47 PM
blacksrtinAZ
I think I would disgree with that. S2 runs10-10.5 AFR under boost. With the larger injectors your going to fall well below that and well into the low 9's. You'll actually lose power
I would agree that normal cruising speed, the ECU/PCM will make the corrections to run around 14.7 AFR. But he'll have more PTB issues with the larger injectors without some control and dip-in knock issues.
