BOV???
dealerships can't void your warranty unless they can prove that the problem that you have is caused by the part that you installed. thats the way is SHOULD happen....thats not the way it USUALLY happens.
bottom line is that it shouldn't void warranty but if you end up bringing your car in for warranty work, they will probably blame it on the bov. it also depends on the dealership. Some dealerships are "better" than others, when it comes to warranty work on modded cars.
It's best to ask your dealer and make a note of whom you talked to and when. My dealer has been very tolerant of my mods since I take my SRT-4 to them forall the oil changes, body work, etc.
Dusty
Dusty
thanks, ill definately do that.....cuz i know how sick a BOV is, and at the same time i dont want to mess anything up...my car only has 4339 miles on it and im wondering what other mods can i do to make it faster but still cheap
If you don't have one already, get an Oil Catch Can installed since the PCV valve allows oil to blow past and gunk things up. More info can be found at the top of this section........
Dusty
Dusty
ORIGINAL: 2k5srt4stg1
with thatbeing said,
i dont know your mods, but the basics that people usually start with is:
stage 1 pcm
WGA (AGP or Kinetic)
mbc
Trending Topics
I just said it wrong, what i meant was what i should i start out with getting starting with the cheapest and working up? Im definately gonna get an OCC and BOV. Im thinking about lowering it too.
ps. thanks psi chick but im really not that dumb....i know a little bit about cars
