any suggestions
Old Mar 2, 2007 | 03:09 PM
Gmoney99's Avatar
Gmoney99
Default any suggestions
Well I'll be getting my 05 srt-4 very soon after a very long time of wanting one and I will be taking it to germany by the end of the year and you know what that means people no speed limit. So if you have some suggestions by all means please let me know. Right now Im planning to get a stage 2 turbo, exhaust, intercooler, boost controler, short throw shifter, cold air intake and some other things. But I will take all advice.
Old Mar 2, 2007 | 05:17 PM
PSI Chick's Avatar
PSI Chick
Default RE: any suggestions
co's or springs and rear tension struts. at high speeds the *** end has a tendency to kick out, don't want that happening at 150 on the autobahn.
Old Mar 2, 2007 | 11:10 PM
flamingpinhead's Avatar
flamingpinhead
Section Moderator
perhaps some wider rims, the stocks are only 6" wide and can only hold 205s (maybe 215s). and if you plan on tinkering with the boost and all youll want a wideband.
(and the stage 2 dosent change the turbo out, only S3. but the S2 w/ toys gives you some nice tinker toys and S2 regardless gives you a bit more punch)
if you want to go all out you could just get the S3. but i really dont know what kind of budget your on. that might help in suggestoins from others
Old Mar 3, 2007 | 02:09 AM
Gmoney99's Avatar
Gmoney99
Default The budget
Well right now the budget is 5G's but Im probably going to spend around 8G's like I said I have a short time to work on it before I take it to germany.
Old Apr 30, 2007 | 03:52 AM
jason vick's Avatar
jason vick
ORIGINAL: Gmoney99
Well I am in Germany (Schweinfurt) so let me give you some advise
one do not tint you front windows you will not pass the inspection
two be careful with exhausts there is a 90 decible limit here none of us pass its a huge problem right now check it out on srtforums.com
three join srtforums.com there is an entire group or us in the overseas 90% military and could probably help you out alot
Old Apr 30, 2007 | 06:33 AM
flamingpinhead
Section Moderator
wow, so if i were to PCS to germany... my window tint and stock exhaust would be a major problem?
Old May 7, 2007 | 09:35 PM
T_U_R_B_O's Avatar
T_U_R_B_O
about how wide of rims u think i can get without rubbing
