Small Problem...
Old Mar 6, 2007 | 10:12 AM
Aceburner's Avatar
Aceburner
Default Small Problem...
Ok after searching forever over here I found some better lines for my OCC. I also found a little breather for the vent side of the valve cover. Soooooo I go to install them and it doesn't go as planned. The problem is when I try to run the line from the valve cover to the breather, it rasies the intake pipe a bit and rubs it against the strut bar (and left and nice scratch). I didn't notice this until after I started the car the other day and heard the intake pipe hit the strut bar. The same goes for the intake side. I dont know how to plug the hole without afecting the height of the pipe. Right now I just took everything off and ran a hose from the valve cover to the intake pipe but I really would like to have the breather and plug the hole. Can anyone help me with this?
Old Mar 6, 2007 | 10:28 AM
redevil's Avatar
redevil
Default RE: Small Problem...
why are you running a line from valve cover to breather.I ran a line from drivers side valve to c.c, and one from t.b to c.c and thats it.Now i gotta find a breather and plug it into driver's side valve or vend side w.e you wanna call that.Then plug the intake hole and that should do it.
Old Mar 6, 2007 | 03:23 PM
Aceburner's Avatar
Aceburner
ORIGINAL: redevil
I took a few pics so you can see. It'll show you what I'm talking about.
[IMG]local://upfiles/50031/73D56AB5616A42C4916677778D581E7A.jpg[/IMG]
[IMG]local://upfiles/50031/AB3B2493B4B443F787E67A957C75ADE4.jpg[/IMG]
[IMG]local://upfiles/50031/A87770943F5E4EAD90CB899969127BFB.jpg[/IMG]
[IMG]local://upfiles/50031/9B28B2D2B08C424A85523E9B7C5138D7.jpg[/IMG]
Old Mar 6, 2007 | 03:27 PM
Aceburner's Avatar
Aceburner
The last pics is where I'm having the problem. If I try to run a line from the valve coverto the breather or even the OCC,the line pushes the intake upward since thenipple on the intake is so close to the valve cover. Am I doing something wrong?
Old Mar 6, 2007 | 03:32 PM
PSI Chick's Avatar
PSI Chick
yea you don't run the breather anywhere. just attach it directly to the valve cover
Old Mar 6, 2007 | 04:54 PM
redevil's Avatar
redevil
hope my post and chick's helped, if not I'll take a pic of mine and I'll show you, or go to myspace and check out my pics, there is one withthe hood open.
Old Mar 6, 2007 | 06:37 PM
Aceburner's Avatar
Aceburner
I had it right the first time after looking at your pics. Thanks. I'm mad now cause I got a scratch for no reason. Oh well, I know a guy who can fix that for me.
