Car starts funny! HELP!
Old Mar 21, 2007 | 11:22 AM
jmsrt4's Avatar
jmsrt4
Default Car starts funny! HELP!
I started my car this morning and its wasnt sounding right. The check engine light came on and it idles really low. Car shaking much more than normal and I noticed white smoke comming from exhaust. More than normal. I cant check the oil level becuz its still to dark. Does anybody have a clue what this could be. The car is stock no mods. Oh yeah, I also smells like really strong gasoline while its on.Any info would be appreciated.
Old Mar 21, 2007 | 01:55 PM
PSI Chick's Avatar
PSI Chick
Default RE: Car starts funny! HELP!
what code is thrown?
i'm going to guess P0123
Old Mar 21, 2007 | 03:24 PM
SRT_YA's Avatar
SRT_YA
is that the TPS error code??
Old Mar 21, 2007 | 03:59 PM
jmsrt4's Avatar
jmsrt4
I didnt see any codes thrown. I am assuming they are shown on the dash where the milage is.
Old Mar 21, 2007 | 04:00 PM
jmsrt4's Avatar
jmsrt4
Ill go check again.
Old Mar 21, 2007 | 07:37 PM
PSI Chick's Avatar
PSI Chick
yea that's the tps
Old Mar 22, 2007 | 01:15 AM
jmsrt4's Avatar
jmsrt4
ok I recieved the code p0202. turns out it was the #2 injector. I dont understand how this happened. I pulled it and put it back in. Everything seems to be fine now. However, should I go ahead and replace it?
Old Mar 22, 2007 | 01:25 AM
silverblacksrt4's Avatar
silverblacksrt4
i would replace all of them to be safe.. but thats what id do!!!
Old Mar 22, 2007 | 04:15 AM
PSI Chick's Avatar
PSI Chick
how many miles are on the car? it's possible that the injector went bad. before spending the cash on injectors though, throw some injector cleaner in there and see if it helps. after that, reset the ecu and see if the code comes back. if it does, then you probably need new injectors
Old Mar 22, 2007 | 11:18 AM
monstab757's Avatar
monstab757
Well if you are still under warranty and have no mods like you say, I would take it to the dealership and have them give you all new injectors. Problem solved.
