The right boost controller? (Manual)
Old Mar 25, 2007 | 08:04 PM
futuremods's Avatar
futuremods
Default The right boost controller? (Manual)
I just joined the forum recently and was wondering what the right manual boost controller to use, i was looking at the (in-cab manual boost controller) from NeedsWings performance, was also wondering what PSI i can safely push with having no other mods on the car. 18, 20, 21, 22??? i do not know. would really apriciate any advice. Thanks, futuremods
Old Mar 25, 2007 | 09:43 PM
PSI Chick's Avatar
PSI Chick
Default RE: The right boost controller? (Manual)
stay away from the incabins if you can, they're not as accurate and not really necessary. once you set your boost levels you don't really adjust.
on the stock fuel system don't go more than a 18-19psi spike holding 16-17psi.
as for which one to use, that's up to you. they're all basically the same thing. the kinetic and the turbo xs are the most popular though.....
Old Mar 26, 2007 | 02:20 AM
SMTYLEZ's Avatar
SMTYLEZ
i noticed turbo xs has different types of mbc, diff stages like dual, reg. and high perf. whats better for holding 16-17 psi spiking 18-19? reg. or dual stage?
Old Mar 26, 2007 | 02:27 AM
silverblacksrt4's Avatar
silverblacksrt4
dont get a manual boost controller.. they suck and dont work that good.. i have the greddy prospec II.. its awesome!
