boost controller on stock wastegate good or bad?
Old Mar 26, 2007 | 07:00 PM
SMTYLEZ's Avatar
SMTYLEZ
Default boost controller on stock wastegate good or bad?
mbc good with stock wastge gate or no lol???
Old Mar 26, 2007 | 07:05 PM
Valo2170's Avatar
Valo2170
Default RE: boost controller on stock wastegate good or bad?
no cause the spring sucks anyways in the stock wg! if you were to get a agp wg you can use it. i mean you can use it but you cant turn it up anymore then what it can do cause ofthe spring.
Old Mar 26, 2007 | 07:31 PM
silverblacksrt4's Avatar
silverblacksrt4
first off i think mbc suck but it can be done but not up that high.. second the an electronic boost controller.. they are better.. and then upgrade ur wastegate.. i recom. agp one or if u going to get the mopar st.2 or st.3 they come with one!!!! its ur call whatever ur budget is.. but i wouldn't hook up a manual boost controller.. heard bad things, seen bad things about them!
Old Mar 26, 2007 | 08:41 PM
PSI Chick's Avatar
PSI Chick
there's nothing wrong with a mbc as long as you get one with a lock nut on it. most people use mbc's on their cars rather than ebcs. they're easy to adjust and cost a LOT less.
you could put a mbc on astock wga, but you'll be better off getting a stronger wga.
